February 13, 2026, 11:17:43 PM *
Author Topic: Need advice/opinions re. valve seals on my 1200....w/pictures.  (Read 1004 times)
« on: January 14, 2018, 12:01:08 PM »
I had one of the valve spring compressors like the picture below. The two different length arms created problems partly due to lack of space for access to the intakes, combined with the width of one of the arms. I finally broke down and bought a second spring compressor and switched arms around so I now have two...one has matching length long arms and the other matching length short. Once done, I was finally able to remove the springs on #1, should have done the switch a couple weeks ago but life tends to happen, more so as you age. So, went to install the first new valve stem seal by lightly tapping it into place with an installation tool. Suddenly, I realized the upper half of the seal had separated from the base....probably a good thing I went to church this morning. Wink The bottom section hadn't yet dropped into the "valley" or notch a fraction of an inch below the top of the guide and the top of the guide caused the top half to separate/tear. I assume that's where it's supposed to sit(in the notch) in order to prevent the seal from moving up/down with the valve. Frankly, I didn't pay attention to where the OEM seal was situated before removing it so I may have to remove another valve spring just to be certain. I used the damaged new seal to test it and by pressing it a bit further down it did drop into the notch that exists a slight bit below the top crown were the valve stem exits. I ordered these off Ebay, a viton based product and supposedly were for the 1200 and a number of other Honda motors.
I guess my question is this; aren't the seals supposed to slip all the way down into the "valley" or notched area slightly below the top wider section of the guide? If I need to I guess I could just order some OEM seals, that gets a bit pricey for only eight at $9.56 ea.
Pictures are worth at least a dime, so this is the "notch" on the valve guide to which I'm referring. I've slipped a new seal on only as far as just covering the top "crown" of the valve guide, then manually moved the valve stem up/down to see what would happen. As suspected, on the second movement up which would simulate the valve closing, the seal came up with it. Tried it a couple more times, same action of the seal and when pressing the valve back in(open) the seal doesn't reseat itself. So again my question is....shouldn't the valve stem seals sit in that smaller diameter area below the top of the guide, the area I'm pointing to in the second picture?
Valve spring compressor before modifying the arms to be of equal length.
Note the groove below the upper "crown" of the valve guide.
Better picture of the groove where I think the seal should sit upon installation. Experimenting with the old seal, when pressed down past that upper "crown" to the groove below it, the seal actually snaps into place which makes me think that's where the new seal should sit. Understand....the only reason I'm even doing the seals is because of some smoking upon start-up, more so if the bike has been sitting for a while. I'd just as soon the prospective buyer be able to breathe while checking out the bike.
Redline +
Northwest Washington
« Reply #1 on: January 14, 2018, 01:23:26 PM »
Yes John, the inner rubber ring of the valve seal should engage with the retaining groove on the valve guide outside diameter. Sometimes the generic aftermarket seals just don't quite fit, they make them so they fit several different engines, but not well.
Step one, throw the installation tool in the garbage, with the correct seal, lube the inside of the seal with motor oil, and with a twisting motion push the seal onto the guide by hand until you feel the seal engage with the groove. Give the seal a few more twists to make sure it's sitting square on the guide.
For the last 45 years I've owned an automotive machine shop and buy valve seals in bags of 500, so I've done this a few times...
Redline Cool
« Reply #2 on: January 14, 2018, 02:54:51 PM »
Yeah, sounds like it.  Grin  I've done it a few times myself but not on one of these motors, mostly on cars but has been a few years so memories fade some. Only reason I used the tool is it came in a kit someone offered me for "my price".....free.  Wink  Had the kit for a while now, has various size insertion tools that are for different diameter valve stems....stuff I'll never use but it might come in handy some day....paper weight maybe.  Grin  I'm planning on checking a couple nearby Honda dealers to see if they have any sets of seals in stock so I don't have to order them....just go with OEM and be done with it. Thanks for the advice, I'll be taking another look at the project this week.
« Reply #3 on: January 14, 2018, 07:49:01 PM »
OK, this evening I pulled another set of valve springs to see how far down the OEM seals sat on the guide. It's as I suspected and Redline verified so I went ahead and replaced the four on the right side. This time I just used my fingers to press in place with a slight twisting action. Took a little over an hour, probably could have done it in less time but I just don't bend down that far very easy any more. Next, the left side will be even more of a problem for these old joints 'cuz I have to do it on the sidestand. That puts the left side lower and at a sharper downward angle. Thinking I might put my jack under it and raise the bike a little higher and level, use some jackstands to stabilize. If the spirit moves me tomorrow, I might finish the left side and be done with it. Be advised....the spirit hasn't been too active as of late.  Wink
