February 14, 2026, 01:06:28 AM *
Author Topic: '98 Starter Solenoid  (Read 1554 times)
Murrgh
Williamsburg, VA
« on: January 15, 2018, 11:12:07 AM »
Starter Solenoid is acting up as of this morning. Was looking at getting a few spares, but they all get pretty poor reviews online. Anyone have one that they recommend?
Tried searching and didn't come up with much.
« Reply #1 on: January 15, 2018, 11:48:46 AM »
What do you mean by acting up?
indybobm
Franklin, Indiana VRCC # 5258
« Reply #2 on: January 15, 2018, 01:10:30 PM »
Majority of the time people think that their starter solenoid is acting up it is the starter button that needs work.
So many roads, so little time
VRCC # 5258
« Reply #3 on: January 15, 2018, 02:43:55 PM »
The solenoid (called the starter relay switch by Honda) is unlikely to fail at the frequency needed to carry a few spares.  I've never replaced mine, and don't have a spare.  The thing to do to keep it working well is unplug the connector, clean the connecting surfaces on both sides of the connector with contact cleaner, then perhaps add dielectric grease to prevent corrosion before reconnecting.  When they fail, it's because the connection fails and overheats, melting the connector and probably making the solenoid fail, although I've never seen one dissected after failure.
JimC
SE Wisconsin
« Reply #4 on: January 15, 2018, 03:14:15 PM »
I agree it is probably the start button, but with the cost of the replacement solenoids it will not hurt too buy a spare. Check out the link below.
https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=valkyrie+starter+solenoid
Jim
Jim Callaghan    SE Wisconsin
« Reply #5 on: January 15, 2018, 05:01:07 PM »
Starter relay?
Starter button or low battery. Easy to check the battery. Known good battery (daily driver), and hook it up to your bike.
What is going on to make you think it's the relay? What problem are you having.
Murrgh
Williamsburg, VA
« Reply #6 on: January 15, 2018, 06:22:05 PM »
Twice in the last few days, I've been unable to start. Lights come on with the ignition switch, I press the starter button, the headlight goes off, and then nothing. I did some research and decided to try and short the starter relay. Tried starting after and she came alive with no issues. Same thing happened this morning. I just figured replacing the relay might fix this.
New battery, verified fully charged as well.
RonW
Newport Beach
« Reply #7 on: January 15, 2018, 06:30:49 PM »
The start button triggers ON the starter relay like a wall switch turns on the lights. That's why they were pointing to a faulty start button that's unable to trigger ON the starter relay.
« Last Edit: January 15, 2018, 06:34:19 PM by RonW » Logged
2000 Valkyrie Tourer
« Reply #8 on: January 15, 2018, 06:49:25 PM »
Take apart your start switch. Probably just needs cleaned up. Be very careful not to lose the little springs and parts.
OzValk
« Reply #9 on: January 15, 2018, 07:16:29 PM »
Fwiw
I had same bike symptom. The great advice on this site had me check battery, then disassemble ignition and starter assemblies  and thoroughly service/clean. I cleaned everything i could find in ignition circuit..
Reassembled and bike started.
I found nothing broken and reckon it was just the effect of 17 years.
Reminded me theres plenty maintenance ahead of me.
Cheers from Downunder.
Murrgh
Williamsburg, VA
« Reply #10 on: January 15, 2018, 07:35:03 PM »
Thanks everyone for the advice. I will be cleaning the starter assembly next!
« Reply #11 on: January 16, 2018, 04:17:13 AM »
You will be a happy man when you do cooldude
« Reply #12 on: January 16, 2018, 07:28:14 AM »
Assuming you mean starter switch assembly beside the right hand grip.  cooldude
BTW, the headlight is supposed to go off as you're depressing the start button.
« Reply #13 on: January 16, 2018, 08:47:14 PM »
You'll find the How-To in the Shoptalk section.
http://www.valkyrieriders.com/shoptalk/VSGPages/starterbutton.htm
Some have needed to do it twice, so make sure you get ALL the old lubricant out of the holes the springs are in.
« Reply #14 on: January 16, 2018, 09:11:04 PM »
http://www.rattlebars.com/mtz/starter.html
« Reply #15 on: January 17, 2018, 04:58:58 AM »
Make sure the little contact is free to bounce up and down on it's little spring.
