February 14, 2026, 01:06:49 AM *
Author Topic: GL1500C Cranking current  (Read 1201 times)
SteveNZ
New Zealand
« on: January 19, 2018, 01:41:15 PM »
Anybody know the amps required to crank the old girl? looking to add one of em lithium ion jump starters to the saddle bags.
« Reply #1 on: January 19, 2018, 03:25:15 PM »
Why? Keep a good battery and that other stuff you are talking is wated space and money..
Savago
Brentwood - CA
« Reply #2 on: January 19, 2018, 04:41:46 PM »
Once my battery was dead and I was able to jump start it using one of these:
https://www.amazon.com/Antigravity-Batteries-XP-3-Portable-Flashlight/dp/B075YC2NYG/ref=sr_1_fkmr0_1?s=automotive&ie=UTF8&qid=1516410147&sr=1-1-fkmr0&keywords=Antigravity+Batteries+Micro-Start+PPS+XP-1+Multi-Function+Jump+Starter+%2F+Personal+Power+Supply
It says at product description: "The XP-3 has 200 Amps starting current with 400 Amps Peak" and "Great capacity for back-up power: 8000 mAh".
Hope it helps.
« Reply #3 on: January 19, 2018, 05:15:15 PM »
Can't answer, other than the YTX14-BS battery is the following.
Battery Family: Maintenance Free
Battery Type: YTX14-BS
Voltage: 12
Capacity: 12
Dimensions: 6" x 3.4375" x 5.75"
Weight: 8.1 lbs.
Metric Dimensions: 150mm x 87mm x 145mm
Metric Weight: 3.7 kg
Polarity:
Acid Volume: 0.69
Amps: 1.4
C.C.A.: 200
I would think any boast of 200 Amps should be capable of starting our bikes. Now, the issue would be how many times.
Leathel
New Zealand
« Reply #4 on: January 19, 2018, 05:29:56 PM »
I wonder how easy the Valk is to push start? I had to push the VT1100C once to start it when the starter failed and it was not easy but got there .....but it has 550cc cylinders ..... 6 250 cc cylinders should be easier?
 I might have to try one day..... not often riding alone so usually someone to push..... That lithium jump packs work well though Tongue
« Reply #5 on: January 19, 2018, 05:56:23 PM »
I use a NOCO GB40. Find it on Amazon.
WintrSol
Florissant, MO
« Reply #6 on: January 20, 2018, 02:04:20 PM »
I have the XP-2 Micro-Start, which claims 12000mAh capacity and 400A Peak; it lets me crank my old cold-hearted CB450 quickly and easily after it has sat too long, and barely uses any power stored in the XP-2. The 450 uses the same size battery as the Valkyrie, BTW. On trips, I keep the XP-2 in my saddlebags, for luck.
