Steve, it is a little HAND manuvered drill. Yaa turn it with your finger tips......
Stop by the house sometime and I'll show ya one I used to use years ago when drag racing.
This was the way to cheat legally.. LOL........
RJ,
Stop trying to dumb f*cker me.
You think I don't know what a pin vise is? I have two (different sizes) in one of my toolboxes. I was a machinist and toolmaker for longer than I can remember....Remember?
1) A drill will not cut a perfect hole.
2) If you want a perfectly symmetrical hole, you need to use a boring bar, but in this case a reamer will work.
3) Like was said below, you use a drill and you will likely put a nick in the hole making the jet useless.
The ONLY way to be sure the holes are a consistent size is to ream them.
4) Also mentioned...Manufacturing tolerances. Yes, there are manufacturing tolerances on just about everything, there has to be. But a carb jet? A hole that small? ??? I've never made jets before, but I imagine the tolerance is no more than +/- .0001.
5) Buy a new set of jets and put the stock ones away in case you want to go back.
