February 14, 2026, 01:06:31 AM *
Author Topic: Head Gasket Question  (Read 1431 times)
moreira72
VRCC# 33494
Clark, NJ. 07066
« on: January 28, 2018, 08:39:22 AM »
I have a 1999 Interstate with 52k miles, desmogged, cobras 6x6, K&N filter. So bike has been smoking a bit. I removed exhaust to do truck stacks and found a couple of the exhaust ports saturated with oil. I suspect bad valve seals. So I was gonna order new seals and head gaskets.
My question is there are two head gaskets available from Honda. A standard gasket for $25 each, and a (0.75/1.00) for $72 each. What is a 0.75/1.00? is that the thickness? and do I really need it, or is the standard good enough? Don't want to spend an extra $100 bucks on head gaskets if I don't need them. Any input would be appreciated.
da prez
Wilmot Wi
« Reply #1 on: January 28, 2018, 09:07:10 AM »
Valve guides can be changed with out pulling the heads.
                            da prez
« Reply #2 on: January 28, 2018, 09:32:48 AM »
Oil in the port. I'm thinking ex-hydro lock with damage.
How long have you had this bike?
Start with a compression test. Work from there.
indybobm
Franklin, Indiana VRCC # 5258
« Reply #3 on: January 28, 2018, 09:37:57 AM »
I'm pretty that the valve guide seals can be replaced without moving the heads. The second listing for a head gasket, (0.75/1.00) might be for an overbore/engine rebuild.
So many roads, so little time
VRCC # 5258
moreira72
VRCC# 33494
Clark, NJ. 07066
« Reply #4 on: January 28, 2018, 10:04:15 AM »
                            da prez
How would I remove the keepers and springs wouthout holding the back of the valve. And don’t you have to remove the valves to tap in the new guides? If it could be done, I would love to do it without removing the heads.
moreira72
VRCC# 33494
Clark, NJ. 07066
« Reply #5 on: January 28, 2018, 10:11:40 AM »
Compression is in spec. Bike runs great aside from a little smoke. Engine is quiet no valve noise. 35-37 mpg.
RonW
Newport Beach
« Reply #6 on: January 28, 2018, 10:28:35 AM »
new guides, or new seals??
2000 Valkyrie Tourer
moreira72
VRCC# 33494
Clark, NJ. 07066
« Reply #7 on: January 28, 2018, 10:36:09 AM »
just seals, but if I could do guides without removing heads I would replace them as well
RonW
Newport Beach
« Reply #8 on: January 28, 2018, 10:59:54 AM »
if you do end up removing the heads, remember to get 2 o-rings for the water pipes that plug into the heads. I forgot those and had to special order them putting the entire project on hold, didn't want to risk re-using the old o-rings. The shipping cost was more than the actual items. They're listed on the water pipe Oem parts webpage. Not the cylinder head page.
moreira72
VRCC# 33494
Clark, NJ. 07066
« Reply #9 on: January 28, 2018, 11:24:42 AM »
thanks, yes I have those on my order list along with new timing belts. did you use the standard head gaskets? $25 each or so
RonW
Newport Beach
« Reply #10 on: January 28, 2018, 01:25:19 PM »
I bought the standard gasket. The old gasket was pristine and probably could have been re-used. It practically fell off. No residue to scrape off either. There's a 6mm bolt that belongs on the bottom of the cylinder head which the manual doesn't state a torque value for. You might gauge the exiting torque on the 6mm bolt using an inch-pound torque wrench starting at 6 ft-lbs (72 in-lbs) and working up until the bolt turns. Both left and right 6mm bolts came out okay, but one of them gave me trouble reinstalling it. I felt the head of the 6mm bolt spin independently of the bolt shaft, so I immediately started reversing out the bolt. Found that the shaft of the bolt was hanging on by a thread. Dunno if they're torque-to-yield bolts and aren't suppose to be used twice or was just an anomaly.
moreira72
VRCC# 33494
Clark, NJ. 07066
« Reply #11 on: January 28, 2018, 01:37:32 PM »
Thanks, gonna order all the parts I need tomorrow. cooldude
Pete
« Reply #12 on: January 28, 2018, 01:57:03 PM »
Been a while since I did a valve guide replacement.
Years ago the guides were reamed to valve stem size after install.
So heads came off and valves came out for guides.
Seals were always done with head on unless you were doing both, guides and seals.
« Last Edit: January 28, 2018, 06:04:34 PM by Pete » Logged
Itinifni
Boston
« Reply #13 on: January 28, 2018, 03:46:23 PM »
Seals can be replaced without removing the heads is you have the tools, you'd need:
1) A valve keeper removal tool that doesn't need access to the valve face. I have a magnetic tool that works very well but I don't know if there would be enough clearance on the Valkyrie head.
2) A compression gauge with a quick disconnect hose and the correct end to thread into the Valkyrie plug bore.
3) A regulated air supply
4) A seal driver, any time I have not had a dedicated seal driver I've been able to find a 3/8" drive deep socket to install the seal without damage.
Pull all the plugs and set the cylinder you'll be working on to TDC (important!).
Set the regulator on your air line to 10-15 PSI.
Thread the compression gauge hose into the bore and connect your air hose to the other end (you'll need to have the correct quick disconnect on your air line).
If you're not sure if you're on TDC crank the air pressure to 40 PSI or so, if you're off dead center the crank will spin 180* with no harm done.
If you are on TDC there'll be no crank movement.
You can now use the tool to remove the keepers, retainer, spring and seal, drive the new one on, and reassemble. The air pressure will hold the valve in place.
You can now move onto the other valve in that cylinder and if you have the cams out of both heads at the same time you can also do both valves on the companion cylinder without re-setting the crank.
Good luck!
73? CT70
79 CB750K
82 GL1100
94 CBR1000F
Kid
Kid
97 Valkyrie Std. (May surpass the GL1100 as the best bike I've ever owned, I'll update in 50k miles)
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #14 on: January 28, 2018, 04:25:40 PM »
USE THE STANDARD HEAD GASKETS AND ORDER ALL 4 WATER PIPE O RINGS
« Reply #15 on: January 28, 2018, 06:06:12 PM »
I just replaced all the valve stem seals on my 1200 Wing, just involved removing the cam hold down part to gain access to the valve springs. The Valkyrie has basically the same thing, just larger and more robust. Then used a valve spring compressor as in the pic below except I bought two and changed the arms so the arms were the same length. As for using air to hold the valves in place, not necessary. Just get maybe 30" of rope small enough to go into the spark plug hole, then roll the motor over by hand using a wrench on the crankshaft bolt. It will compress the rope against the valves and they don't move. That lets you do both intake and exhaust before doing the next cylinder. Pull the rope out and do the cylinder next to it, etc. I would order new cam oil seals to go on the front of the cam just in case you should disturb it, thereby causing a leak into the timing belt area ruining the belts. You might devise a method of holding the cam in place when you remove the hold-down section, that pretty much guarantees you won't disturb the front oil seal. The heads don't need to be removed and I never needed to use any type of insertion tool to place the new seals on the guides. Just oil up the seals and guides and with your fingers just press them on with a little twisting motion....they'll slip right on. As for a tool to remove the keepers(collets), just pick up a small magnet on an extendable rod, mine is about 1/4" wide and the rod about 1' long extended. It picks up the keepers quite easily.
A little trick to put the keepers back in; by pressing the compressed spring away from the keeper area(down toward the head) the "top" will open up a bit so you can slip the first one in place. Then once it's in place, pull the spring toward you so there's a little pressure on the first keeper, causing it to seat and hold in place. At this time you should be able to turn the compressor/spring still holding slight pressure against the keeper. Turn it enough so the first keeper is now away from the "top" position and you can release the pressure enough to insert the second keeper. Then pull the spring toward you again and unscrew the compressor. Once it's off, use a small mallet to tap on the end of the valve to help seat the keepers completely and you're done.
In years past on car engines I've even removed the keepers without a spring compressor. I stuck a strong narrow magnet inside the proper size socket, placed the socket on the spring washer and a couple good whacks with a mallet caused the spring to compress enough to allow the magnet to pull the keepers up into the socket. Once the spring was off, I'd then use a compressor to reinstall the springs and keepers once the seals were in place.
Forgot to add the picture of the spring compressor used to change seals without removing the heads.
« Last Edit: January 28, 2018, 06:09:58 PM by John Schmidt » Logged
moreira72
VRCC# 33494
Clark, NJ. 07066
« Reply #16 on: January 29, 2018, 10:51:12 AM »
Thanks John for your write-up. I ordered the spring compressor and will replace the seals sometime next week when all the parts come in. I’ll post a follow up and some pics.
« Reply #17 on: January 29, 2018, 11:35:18 AM »
Those compressors are always available at your local auto parts store.  cooldude
If you use the rope method to hold the valves in place, be sure to leave a foot or so hanging out so you can grab it to pull the rope out when done. When I was in the USAF I had a neighbor kid wanting help to change valve seals, so I advised him of the rope method....was on an old 6-cyl. Chevy. I didn't bother to tell him about leaving some hanging out so guess what happened there! Took us a while but were finally able to fish it out.
da prez
Wilmot Wi
« Reply #18 on: January 30, 2018, 04:41:56 PM »
  John , here I thought I knew everything and you teach me something new 2funny. Never knew of the rope method.  uglystupid2
                                                       da prez
« Reply #19 on: January 30, 2018, 05:41:06 PM »
                                                       da prez
Grin Ross, now you can tell the youngsters you learned about it from some old fart back when. They don't need to know how recent "back when" was.  Wink
