February 14, 2026, 01:06:27 AM *
Author Topic: Carbuetor Bank Assembly Thrust Spring  (Read 1043 times)
BIGDOG1954
« on: January 29, 2018, 02:43:13 PM »
Need some help! Does anyone know the purpose of the "thrust spring" located in between the carburetors??
Separating the carbs and spring fell out. Doesn't appear it really does anything. Just want to make sure I install it back correctly. Really curious what it is for....
Any help would be greatly appreciated
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #1 on: January 30, 2018, 10:09:12 AM »
it helps keep the throttle shafts centered so the butterflies don't bind up
BIGDOG1954
« Reply #2 on: February 04, 2018, 09:58:39 AM »
Thanks so much, I really appreciate the reply.
