Mofla
« on: January 31, 2018, 03:30:43 PM » |
Ok , went to crank my girl, to turnover at all. Rode her home from the Bar lSt night with no problems battery seemed dead, read barely 2v, charged, tried start again and just a kinda click with no motor turnover whatsoever, and the dash lights go out ,,,battery reads 12+v, seems like a short, battery probably a year old ? Starter fuse is good , what is the dog bone fuse ? As always thanks for the input !!Mofla,,98 Tourer, approaching 80k
Mofla
« Reply #1 on: January 31, 2018, 03:34:44 PM » |
Just walked out and turned on the key again after sitting a few minutes and lights come on like normal. I didn’t hit started button cause thT seems to knock it all out again ??
Dusty
« Reply #2 on: January 31, 2018, 04:22:44 PM » |
my first guess would be Dirty battery connections or ground wire to frame loose or dirty. Ground wire is down by alternator
Dusty
« Reply #3 on: January 31, 2018, 04:51:18 PM » |
It's really hard to understand you. Bad typing. Hard to guess you're problem. Jump it to your car and if all is good get a new battery and properly charge it before use.
« Last Edit: January 31, 2018, 06:05:51 PM by Chrisj CMA »
« Reply #4 on: January 31, 2018, 05:07:19 PM » |
It's really hard to understand you. Bad typing. Hard to guess you're problem. Jump it to your car and if all is hood get a new battery and properly charge it before use.
"if all is hood" ? Is that gangsta talk ?
oldsmokey
« Reply #5 on: January 31, 2018, 05:46:52 PM » |
Check your voltage drop during crank cycle, again verify all connections and grounds are good and secure.
Mofla
« Reply #6 on: January 31, 2018, 06:28:18 PM » |
Lol , yea , guess I wasn’t clear,,battery reads charged, doesn’t crank at all,,,,and pressing the starter button knocks out the neutral lights like it shorted out ,,,,then resets after a few minutes and the touching the starter button starts the whole process over again,,,,
« Reply #7 on: January 31, 2018, 06:34:36 PM » |
Dirty starter button….take it apart and clean it….if the battery is indeed good...
Mofla
« Reply #8 on: January 31, 2018, 06:41:45 PM » |
Just put extra torque twist to the terminal screws. Fired right up ! Embarrassed but happy ! Was so thinking it was gonna be the starter button! Appreciate it once again guys !!! I’ll work on my typing next !!!
« Reply #9 on: January 31, 2018, 06:45:30 PM » |
You probably still need to service that button
« Reply #10 on: January 31, 2018, 06:46:49 PM » |
Mofla
« Reply #11 on: January 31, 2018, 07:03:47 PM » |
Will do !! Thanks!
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #12 on: January 31, 2018, 07:37:55 PM » |
What big head said service the starter button & clean ground cable on the back of the engine too
« Reply #13 on: January 31, 2018, 07:58:12 PM » |
Hey Bob.....
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #14 on: January 31, 2018, 10:58:22 PM » |
Hey Big Head
