July 12, 2025, 02:49:05 AM *
Author Topic: Electric fuel pump  (Read 1412 times)
namsgt1946
« on: October 30, 2009, 11:37:14 AM »
1999 Valk---has anyone run an electric fuel pump ?  If so ---what kind---where did you purchase and any feedback,  good bad ect.  Thanks
« Reply #1 on: October 30, 2009, 12:02:07 PM »
Why do you think you need an electric fuel pump?
If you have a need, order the one for a 1985/86 Goldwing, the 86 was called a model SEi.
3W-lonerider
Shippensburg Pa
« Reply #2 on: October 30, 2009, 02:08:16 PM »
i tried running an electric fuel pump..mounted the pump and an electric shutoff solenoid down behind the engine on the cross member where the kickstand is..i used a 1 and 1/2 psi pump. problem i had was. the engine ran and smelt like it was flooding all the time while running. took the pump off and mounted the electric fuel shutoff solenoid between the petcock and the carbs and never had any problems with flooding or the bike smelling like it was being flooded after that.
