November 14, 2025, 11:16:34 PM *
Author Topic: Valkyrie Standard Horn Relay Wiring kit  (Read 1255 times)
billyjakester
« on: February 01, 2018, 04:27:39 PM »
Cycle Terminal is currently not offering their single horn wiring kit for Stebel, Wolo, etc. Can anyone suggest another source that would provide the horn relay and horn wiring harness ?
thanx,
bill
« Reply #1 on: February 01, 2018, 04:42:58 PM »
Pretty sure you can get a relay at any auto parts store..
« Last Edit: February 01, 2018, 05:53:16 PM by Bighead » Logged
rockbobmel
Greenfield MA
« Reply #2 on: February 01, 2018, 05:21:45 PM »
https://www.ebay.com/itm/Wolo-Horn-Wiring-Kit-MCHWK-2/112628873766?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
2002 Valkyrie GL1500CD
1996  Shadow 1100 ACE
« Reply #3 on: February 01, 2018, 05:36:08 PM »
Harness?  Really?  I used a std 30amp relay for my Wolo and powered it from the PC-8 fuse panel, triggered by the horn button. Substitute a single fuse holder if you haven't set up a fuse panel. Add a ground wire to a nearby screw.  Easier than running a harness. Relay, $10 at most at retail though I buy them in bulk for much less. Wire, a few cents.
« Last Edit: February 01, 2018, 05:38:41 PM by MarkT » Logged
Harryc
Sebastian, Fl
« Reply #4 on: February 02, 2018, 08:14:09 AM »
This s the one I used. https://www.amazon.com/dp/B005I4DNP2/?tag=googhydr-20&hvadid=232428892726&hvpos=1t1&hvnetw=g&hvrand=14713608413046198766&hvpone=&hvptwo=&hvqmt=e&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9004867&hvtargid=kwd-304889419094&ref=pd_sl_9slp4867d5_e
« Reply #5 on: February 02, 2018, 09:26:15 AM »
I have a Wolo on one bike and Stebel on the other. Both came with a relay so the install is easy, run the relay off the bike's horn button and feed the horn from a fused wire either off the battery or another good 12v source, the neg. to a good ground as Mark said. No commercial harness needed.....don't overthink the project.
billyjakester
« Reply #6 on: February 02, 2018, 01:49:05 PM »
thanx for the info.  Do you prefer WoLo or the Strebel horn ?
« Reply #7 on: February 02, 2018, 02:08:31 PM »
Same horn different name..
Savago
Brentwood - CA
« Reply #8 on: February 02, 2018, 02:15:02 PM »
I recall when I installed a water temperature gauge in my I/S...
I bought Autometer because they are reliable and made in the good and oldie USA. They had the model I wanted in 2 options: *with* the wiring harness (20 bucks or something) or *without* it.
I choose the one *without* the harness trying to save 20 bucks... Damn, it is not rocket science! Just 3 wires (power, ground, sensor).  Right?
Then I had to buy 3 colors of wire (black, red, green), connectors, solder and shrink wrap tubing... ended up spending over 50 bucks.
 Sad
billyjakester
« Reply #9 on: February 08, 2018, 01:43:18 PM »
Followup:  bought the Wolo719 and the Wolo wiring kit ($10).......totally worth it.  Mounting the Wolo where the original beep beep horn was using aluminum flat stock.  Everything works fine, but I'm going to make a new mounting bracket out of flat steel, the aluminum flat stock flexes way too much in the wind and rough road conditions.  Love the sound.
thanx to all,
bill
« Reply #10 on: February 08, 2018, 09:44:16 PM »
Keep in mind, they like the horn to be aimed where it gets air, but I had two under my swingarm, aimed forward, and they sucked up so much water and crud, they didn't last.  Maybe a year each.
Up front on the std horn mount, pointing the horn left or right is a good idea, opposed to forward.
