November 14, 2025, 11:20:42 PM *
Author Topic: Starter Button Spring  (Read 875 times)
Murrgh
Williamsburg, VA
« on: February 13, 2018, 10:03:13 AM »
Hey all,
My starter button spring that holds the metal plate gets stuck down occasionally. I've started carrying a screwdriver on me to fix it since it only takes 5 minutes... but does anyone have a fix for this? I tried to pull the spring out and it didn't feel like I could. It's been cleaned using CLR and WD-40, but I'm still having issues.
Daniel Meyer
The State of confusion.
« Reply #1 on: February 13, 2018, 10:06:49 AM »
Clean, polish up the plastic, lube lightly with white grease. Should be good for a couple years normally...unless you've run aux lights off your headlight circuit without a relay? If so, add a relay...too much load on the switch.
CUAgain,
Daniel Meyer
« Reply #2 on: February 13, 2018, 11:42:05 AM »
Hey all,
I use a small razor knife to clean up the groove the contact rides in. That's the part that usually gets stuck.
« Last Edit: February 13, 2018, 11:46:03 AM by Chrisj CMA » Logged
