November 14, 2025, 11:17:52 PM *
Author Topic: Bike back firing  (Read 1478 times)
firefly12
New Orleans,Louisiana
« on: February 15, 2018, 05:46:47 AM »
I just finished rebuilding carburetors and replaced all the vacuum hoses. cranked the engine up and let it warm up. was fast idling it. When i let off the gas i got some back fires. Any en-site on a possible problem i might be having ?
« Reply #1 on: February 15, 2018, 05:58:52 AM »
Check all the plastic hoses that connect the carbs to the intakes.  use a little mirror to examine the backsides.  Air leak is a main cause of backfire from either intake or exhaust.
Paladin528
« Reply #2 on: February 15, 2018, 06:07:44 AM »
Backfiring or popping in the exhaust?
« Reply #3 on: February 15, 2018, 07:06:59 AM »
Along with the hoses, check the little vacuum plugs on the intakes.
firefly12
« Reply #4 on: February 15, 2018, 07:43:15 AM »
all the vacuum lines are new the only thing i did not change were the o rings on the chrome intake
firefly12
« Reply #5 on: February 15, 2018, 08:30:15 AM »
its more of a loud popping then an actual back fire.  My experience with back firing is one big pop. this is more of a couple loud pops
« Reply #6 on: February 15, 2018, 08:57:50 AM »
So you did like Chrisj CMA suggested and checked the backside of the rubber boots that connect the air box to each carburetor, where they connect to the carburetors?
firefly12
« Reply #7 on: February 15, 2018, 10:21:10 AM »
in the process of doing that now
larue
Clermont,FL
« Reply #8 on: February 15, 2018, 12:02:41 PM »
Make sure your exhaust headers are snug
Steel cowboy
Spring Hill, Fl.
« Reply #9 on: February 15, 2018, 02:25:10 PM »
Did you sync the carb's yet
replace the o rings from the manifold to the heads too.
2001 black interstate
2003 Jupiter Orange wing
« Reply #10 on: February 15, 2018, 07:48:13 PM »
any harm done to anything when letting off the gas having popping sounds coming out of the exhaust?
« Reply #11 on: February 15, 2018, 08:15:37 PM »
When I blew the (desmogged) vacuum caps* off the inside intake nipples (where vacuum lines are removed), and the bike backfired LOUDLY on fast freeway decel, I had cage drivers taking evasive action thinking shots were fired.  It was loud as rifle fire.  I don't think it hurt the bike much, but the swerving cages made me nervous.  Was on a long ride home from Asheville NC, and it didn't take long to figure out how to decel slowly to stop most backfire (just don't drop the throttle all at once).
*After I got home, I found one blown in two, and two badly torn.  Those caps were under a year old, but were not up to the task.  Run of the mill auto parts vacuum caps suck, in that application.  The sucking and blowing our fat girls do at that location require heavy duty caps.
firefly12
« Reply #12 on: February 16, 2018, 06:00:41 AM »
found my problem one of the air intake to the carb was not completely on. Problem solved thanks everyone
Savago
Brentwood - CA
« Reply #13 on: February 16, 2018, 11:06:43 AM »
Nicely done!
RonW
Newport Beach
« Reply #14 on: February 18, 2018, 10:54:28 AM »
When I installed the rubber boots to the intake runners, I was able to see the back side of the right boots from the left side of the bike and vis-a-versa for the back sides of the left boots. I didn't have to use a mirror. Just a flash light. This was after desmogging ..... without all the air injections pipes and clutter obstructing the area between the banks of rubber boots. That's another advantage of desmogging.
2000 Valkyrie Tourer
« Reply #15 on: February 19, 2018, 02:18:50 AM »
. Yeah, those OEM caps turn brittle over time and crack.  I use the left over rubber hose from desmogging with bolts screwed into them and they've lasted years.
