July 11, 2025, 10:17:21 PM *
Author Topic: Fork leaking  (Read 3513 times)
Doc X
« on: October 31, 2009, 11:03:18 AM »
My right fork is leaking which I assume the bike needs new fork seals????? I would replace both seals so What Do I Order? Seal set front forks, I guess it fits both sides???
Thanks for the help again.
Doc X
« Reply #1 on: October 31, 2009, 01:38:07 PM »
What you order depends on miles on the bike. You need 2 sets of seals (includes the dust seal). Might need 2 sets of bushings (2 guide and 2 slider bushings). Approx 50 oz's of fork oil. 10 wt is stock but I use 15 weight. I like the crisper feel in the front. Who is going to do the work? You need a couple of special tools to install seals and remove the large nut in the left side fork.
Doc X
« Reply #2 on: October 31, 2009, 02:08:11 PM »
sandy, the guy I trust at the Honda dealer will be doing the work.
Doc X
Steve K (IA)
Cedar Rapids, Iowa
« Reply #3 on: October 31, 2009, 09:15:56 PM »
   SEAL SET, FR. FORK
51490-MW0-003    $20.43   order 2....each set contains 1 oil and 1 dust seal
     BUSH, GUIDE
51414-MT7-003    002    $13.41    order 2
     BUSH, SLIDER
51415-MCH-003    002    $6.30      order 2
28     O-RING (44.7X2.4)
91356-KZ3-003    002    $2.50      order 2   this goes on the top cap.
$85.28 for parts
States I Have Ridden In
PAVALKER
Pittsburgh, Pa
« Reply #4 on: October 31, 2009, 09:25:10 PM »
Doc X
Well since you intend to get your trusted dealer to do it.... you don't need to order anything.... they do.  Tell them you want both front fork seals replaced and leave it to them.  However, if it were me....  I would also have the bushings done.  Get both forks done.... sorta like headlights... when one goes the other is close behind I think.
JMO
John
Doc X
« Reply #5 on: November 01, 2009, 04:28:42 AM »
Thank You All,
Doc X
MP
North Dakota
« Reply #6 on: November 01, 2009, 04:58:29 AM »
Do the bushings too, especially since you are already paying labor to get to the bushings.
MP
"Ridin' with Cycho"
gaurocoen
« Reply #7 on: November 01, 2009, 05:08:22 AM »
Steve, love the list of goodies you threw together.  Where is the best place for me to get insturctions?
Gauro
   SEAL SET, FR. FORK
     BUSH, GUIDE
     BUSH, SLIDER
$85.28 for parts
VegasF6
« Reply #8 on: November 01, 2009, 07:51:48 AM »
Steve, you mind telling me where those prices are from?
   SEAL SET, FR. FORK
     BUSH, GUIDE
     BUSH, SLIDER
$85.28 for parts
Steve K (IA)
Cedar Rapids, Iowa
« Reply #9 on: November 01, 2009, 09:47:38 AM »
   SEAL SET, FR. FORK
     BUSH, GUIDE
     BUSH, SLIDER
$85.28 for parts
www.hdlparts.com (Honda Direct Line)
 I have always had good luck doing business with them.
BudMan
"Two's in."
Tecumseh OK
« Reply #10 on: November 01, 2009, 05:21:47 PM »
This is the information and approach I took when doing mine.  This was my first set of seals to replace, and it went off without a hitch!
http://www.valkyrienorway.com/forksprings.html
Buddy
Tecumseh OK
MOOT# 263
VRCC # 30158
1948 EL Harley
2013 F6B Delux
VegasF6
« Reply #11 on: November 01, 2009, 05:33:51 PM »
Much appreciated. Now to decide if I want the progressive springs or the gold valve kit with the racetek forks! And when will I find the time to do this.
Puffs Daddy
« Reply #12 on: November 02, 2009, 06:34:23 AM »
Recently replaced my stock fork springs with RaceTech's (no gold valve kit) along with WorksPerformance shocks. Significant difference all the way around. I'm a happy camper. Chose the RaceTech's over the Progressives on the advice of my mechanic who had experience with both. As for the WP shocks, I got a good deal on a pair from the WP "ebay store" that brought the price down to that  for a comparable pair of Progressive 440's. Though much more expensive than the replacement fork springs, the shocks were also far more effective in reducing front end "chatter" and improving handling.
Frankly, I don't know if opting for the Gold Valve kit from RaceTech would be worth the expense since my Valk now handles about as well as I think I can expect from a bike its size. It still doesn't match my Moto Guzzi Breva1100, but I don't expect it to. I think the Gold Valve kit is simply overkill for a Valkyrie. (YMMV, of course.)
For the record, I'm about 190 lbs and ride solo 100% of the time. Works Performance tunes their shocks for those two variables.
PAVALKER
Pittsburgh, Pa
« Reply #13 on: November 02, 2009, 09:21:43 AM »
I installed the Progressive fork springs and changed fluid to AMSOIL Shock Therapy and so far am very happy.  I have Progressives on my VTX as well and they have been great for a few years now....  For the price, Progressive Fork Springs are really a great improvement.
John
desanshe
White Rock, British Columbia, Canada
« Reply #14 on: November 02, 2009, 07:46:36 PM »
Hi:
I was told of a simple procedure that might help  stop your fork seal leaks.
Often there is a speck of something that gets into the seal and causes a leak.  You go into your old photos and grap a piece of 35mm negative.  You slip this piece of exposed negative up between the
seal and the fork working it up and down.  Be sure to go all the way around each fork.
What happens is the the sprocket holes in the piece of film might grab the speck of dirt and remove it.
It worked for me
sheets
Jct Rte 299 & 96, Calif.
« Reply #15 on: November 03, 2009, 06:26:07 PM »
Same as "desanshe"; Last winter I found a drop of oil, about once per week, from the left side.  After a couple months I did the film strip trick.  Didn't remove the dust seal.  Just slipped the film strip, curve to match the fork tube, up through the seals.  Did a seesaw motion all the way around a couple times.  No more leaks.  That was nearly a year ago.  Worked for me.  Ymmv,  Cool
« Last Edit: November 07, 2009, 07:32:26 AM by sheets » Logged
mikeb
vrcc-29271
dansville mi by lansing mi
« Reply #16 on: November 05, 2009, 03:31:34 PM »
i deal with hyd cylinders at work and we found coating the rod end with grease will do the same thing weird as it sounds.. but true i guess the grease carries the dirt out with it too
i dont care what you ride just ride
mike & kari
mivrcc capital city leader
s.s.d.d.
F6MoRider
Lakeland, FL
« Reply #17 on: November 10, 2009, 10:04:19 AM »
Check out http://www.hondapartsnation.com/pages/parts/viewbybrand/parts.aspx they are almost 10% cheaper than HDL.  The 51490-MW0-003 is $19.37 vs. $20.43 at HDL.  A buck or two per item adds up fast.  They are in MI so if you live there, you'll pay sales tax to them (as I would here in FL or if I were in OH using HDL).
Hope it helps...
   SEAL SET, FR. FORK
     BUSH, GUIDE
     BUSH, SLIDER
$85.28 for parts
VRCC #4086
2000 Valk Standard dressed with matching Interstate Bags and the Hondaline shield.
