February 14, 2026, 03:08:07 AM *
Author Topic: New Avons Cobras!  (Read 1546 times)
Forge
San Antonio, TX
« on: March 01, 2018, 02:22:32 PM »
I just got and installed a new set of Avon Cobra’s on my new to me Valkyrie Interstate! They are a far cry from the 2001 vintage Dunlops that were on her when I brought her home.  uglystupid2
What kind of pressures are you guys with Avons on Interstates running?
Firefighter
Harlingen, Texas
« Reply #1 on: March 01, 2018, 02:28:11 PM »
Many opinions here, I always have at least 40 psi front and rear, 41, 2, 3, ok, under 40 and you risk tire cupping. I run a car tire rear now but same pressures.
« Last Edit: March 01, 2018, 02:32:09 PM by Firefighter » Logged
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
« Reply #2 on: March 01, 2018, 02:54:59 PM »
44 rear
42 front
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #3 on: March 02, 2018, 11:26:11 AM »
44 rear
42 front
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
Harryc
Sebastian, Fl
« Reply #4 on: March 02, 2018, 01:52:59 PM »
Same when I run Cobras.
« Reply #5 on: March 03, 2018, 06:43:10 PM »
44-46 rear and 38-39 front.  I find 40psi front or above is too harsh a ride and since the front tire will last 15K miles or so much more than the 8-10K rear cycle tire,  you can get almost twice the life out of a front cycle tire vs. a rear cycle tire so why not make the ride tad bit smoother over bumps in the road.
You could go 42psi rear but I see no ill effect from even 46 psi rear cycle tire plus riding 2-up would prefer 45-46 over 44 psi riding 1-up.  You want the rear cycle tire to last as long as possible and 45-46 psi will last more than 42-44 psi since not too many cycle tires in the rear will go over 10K miles.
Evie
Naperville, IL
« Reply #6 on: March 05, 2018, 10:12:29 AM »
Look no further...you've done well.    Have 148K on my I/S & been through many tires.  Avon is my preference.    Warning...don't ruin a good set of tires by running the pressure too low.   I run 44 in rear and 38-40 in front.    If you don't keep the pressure up you'll get cupping, particularly the rear.
msb
Agassiz, BC Canada
« Reply #7 on: March 05, 2018, 11:02:10 AM »
Avon Cobras have definitely been the best of the various brands I've had in the 16 years I've owned my IS. Do a lot of two-up riding both day rides and long distance touring, and always keep 44-46 in the rear and 40 in the front, which gives the best ride and also wear.
'99 Red  & Black IS
Forge
San Antonio, TX
« Reply #8 on: March 08, 2018, 07:46:32 PM »
Thanks guys. I'm starting out with 41 front and 45 rear to see how she goes. I appreciate the input.
