March 31, 2026, 04:59:40 PM *
Author Topic: M-16 vrs a windshield......anyone ?  (Read 1186 times)
DirtyDan
Kingman Arizona, from NJ
« on: March 01, 2018, 04:52:44 PM »
Hey all
Wanted ask ya all if anyone has ever tried an M-16/ 5.56 vrs a windshield and what the results were
My buddy is a soldier and tells me they would have to use bigger weapons cause the M-16 wouldn’t do it
So I figured I’d ask ya all
Thank you in advance
Dan
« Reply #1 on: March 01, 2018, 05:00:21 PM »
https://youtu.be/hKxI-3Jfn5Q
Raider
Three bikes
« Reply #2 on: March 01, 2018, 05:02:21 PM »
Been tested lots.  Certainly deflects a bit (amoout depends on range and angle of incidence), but they can dang sure penetrate the windshield and still kill.
« Reply #3 on: March 01, 2018, 05:41:55 PM »
Your buddy may need to go back to boot camp.  What are they teaching the recruits these days?
« Reply #4 on: March 01, 2018, 05:55:32 PM »
The mixed results of 5.56 on vehicles (Windshields, doors, etc) against incoming terrorists was one of the issues that prompted the development of the .50 Beowulf.
The .50 Beowulf, which is usually fired from an AR-15 or M-16/M4 platform, has no problems at ALL penetrating windshields, doors, engine blocks, whatever... Smiley
Pete
« Reply #5 on: March 01, 2018, 06:24:35 PM »
Given sufficient angle and a hard surface and a sharp point bullet deflection is a given. Simply physics at work.
« Reply #6 on: March 01, 2018, 06:26:44 PM »
Hit it at the right angle and water is bullet proof... Yup...
« Reply #7 on: March 02, 2018, 07:43:33 AM »
I remember being taught in Basic Training that the M-16 round was a "Tumbler" round (think wobbly pass instead of a perfect spiral).
So, it could easily depend on where it was in its tumble when it struck the windshield.
Also the M-16 round has alot of velocity but little weight, which gives it less energy than many standard hunting rounds.
« Reply #8 on: March 02, 2018, 09:10:45 AM »
"Tumbler" is a bit misleading.  Thing of the rotation not being completely in line.  That is that the nose holds a spiral in a line but the tail rotates wider as it's a little off center weight wise.  The tumbling begins when the nose hits something solid.  That's what causes the round to do the damage it does.  It is a light weight bullet.
MAD6Gun
New Haven IN
« Reply #9 on: March 02, 2018, 09:20:44 AM »
 If the bullet tumbled in flight it would leave "keyhole" shaped holes in paper targets. Not to mention accuracy would suffer greatly.
DirtyDan
« Reply #10 on: March 02, 2018, 12:43:25 PM »
Thank you all .........more to follow
Dan
Pete
« Reply #11 on: March 02, 2018, 01:09:33 PM »
In the early days of the AR15 the barrel twist was 1 turn in 12 inches. Because of that slow twist the standard bullet could and did de-stabilize way to easy.
That was changed in later models to 1 in 9, 1 in 8 and 1 in 7 to stop the de-stabilization and to stabilize heavier bullets for more penetration.
With modern AR15's there are no real stabilization issues until you approach 90 grains in bullet weight using a 1 in 7 twist. Slower twist barrels introduce this issue with lighter 70 to 80 grain bullets.
bentwrench
Philadelphia,Pa.
« Reply #12 on: March 03, 2018, 01:55:41 PM »
The M855 steel core will punch through more than just windshields.
New Haven, Indiana
« Reply #13 on: March 04, 2018, 08:58:57 AM »
It seems to me that the 7.62x39 would be a more efficient all around cartridge than the 5.56. A heavier 123 grain bullet with about the same bulk for carrying and effective range but in the AR-15 platform which is more accurate than AK or SKS.
Is that why the Beowolf?  Yeah, From what I heard, the 7.62 round didn't work very well in a Ar-15 platform because of the rimmed cartridge and curved magazine.  Don't mind me, I'm not an expert on the Ar-15. I don't own one but have its entirely different cheaper cousin the AR-7.
I heard that the M14/M1A  was favored more for urban fighting because of its ability to penetrate concrete blocks.
rocketray
« Reply #14 on: March 04, 2018, 10:38:16 AM »
our forefathers carried 30 .06    a thousand yard gun..the AR 10 is my next purchase...the 5.56 is a 550 yd gun..Tx is pretty flat
Raider
Three bikes
« Reply #15 on: March 04, 2018, 05:50:55 PM »
The 7.62 round for the AK & SKS (7.62x39) is not a rimmed cartridge.  The body is tapered a bit, hence the much more curved magazines, but no rim.  You are correct- increased bullet weight is the reason for the Beowulf.  Also, not just the M14 (7.62x51 AKA 7.62 NATO), but also the 7.62x39 penetrate concrete blocks and other medium better than the 5.56.
Stitch_in_La
Bentley Louisiana
« Reply #16 on: March 09, 2018, 03:19:48 PM »
Was that throwing the weapon at the windshield or shooting it?
Chuck
DirtyDan
« Reply #17 on: March 09, 2018, 05:01:21 PM »
My buddy is on the way over for campfire tonight
Will show him
More to follow.......
Dan
