March 15, 2026, 01:01:55 PM *
Author Topic: Have you tightened your 10mm exhaust acorn nuts lately?  (Read 1644 times)
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
« on: March 03, 2018, 05:36:42 AM »
 Shocked
« Reply #1 on: March 03, 2018, 05:40:23 AM »
No but it's probably time. Thanks for the prompt. Them are sneaky little suckers
« Reply #2 on: March 03, 2018, 05:48:37 AM »
No....'cuz I replaced them with regular nuts 'n lock washers years ago. Haven't come loose since. Reason was simple, I found the acorns often didn't screw down tight enough before bottoming out...which prevents a tight fit. Probably due to the studs not all being screwed in all the way, something I wasn't going to try and correct after being in there for all that time.
« Reply #3 on: March 04, 2018, 12:06:05 PM »
Done  cooldude  Both bikes.  Needed it.  Also did all the intake runner clamp screws.  Dont forget them.  Doubt you can put any locking mechanism on them to keep from having to check em  Wink
