January 30, 2026, 12:21:35 AM *
Author Topic: Bike won't start  (Read 3344 times)
Tomkat
« on: November 01, 2009, 12:33:49 PM »
Good Day Everyone.  I rebuilt my petcock.  Everything went well and done according to instructions from shop talk.  Did the little suction trick before putting the petcock together and the diaphram worked well.   Bike turns over but will not start.  All hoses are connected.  Nothing that I can see is pinched.  Bike is a 2001 IS.  Any advice would help.  Thanks Tomkat.
« Reply #1 on: November 01, 2009, 01:50:15 PM »
Outta gas........was on reserve to make the tank light, now you have it on  "on"  has been done before....or maybe a weak battery?
Valker
Wahoo!!!!
Texas Panhandle
« Reply #2 on: November 01, 2009, 02:15:22 PM »
My guess would be a kinked vent hose when replacing the tank....ask me how I know.
Tomkat
« Reply #3 on: November 01, 2009, 02:32:05 PM »
Nope not out of gas.  Battery fully charged.  No problem turning over.  Seems like not getting enough gas.  Vent hose looks OK, will check again.  Tomkat
Tinman
Manvel Tx
« Reply #4 on: November 01, 2009, 02:34:10 PM »
Well then back track.
Was running. Took it apart and now it just turns over but will not start.
It's not a gas problem. It should start and run for quite a while on what
is in the carbs.
What else did you do?
Unplug any additional wires?
IK would pull the tank and look check all wiring in that area
making sure all plugs  are pushed all the way in.
Also check the red stop switch on the handle bar.
I'm thinking that it does not crank either if that is off.
1fastbob
South Central Kansas
« Reply #5 on: November 01, 2009, 02:59:24 PM »
Did you by mistake put the vacuum hose from #6 on the vent line and the vent line on the petcock.  If so I won't run.
In addition to that I would look for a kinked fuel line.
Bob
I'm on somebody's list! BFD!
Chrome
London Ontario Canada
« Reply #6 on: November 01, 2009, 03:47:56 PM »
Hi Tom Not to seem like a smart ass but did you put the petcock back on right? I did mine and had the petcock shaft on 45 degrees out.When I had it on the "on" position,it was actually on "Off" It ran for a very short time and died.
Adrian
2001 Valkyrie I/S
1999 Valkyrie I/S
1998 Ace Tourer
1984 V45 Sabre
1976 CB 750 SuperSport
1969 CB 750 Chopper
John U.
Southern Delaware
« Reply #7 on: November 01, 2009, 03:55:15 PM »
It is possible to reassemble the petcock oncorrectly, it's also possible to connect the vacume line to the vent nipple. Is there enough gas in the carb bowls to start the engine, if not you will have to apply some suction to the vacume line to get gas to run into the bowls before anything will happen.
This last item had me inventing expletives after tank and carb work.  Angry
MP
North Dakota
« Reply #8 on: November 01, 2009, 04:04:16 PM »
Open a drain screw on a carb.  See if there is gas.  Disconnect the vac line where it attaches to #6. Then, with the gas valve on, suck on the end of the vac line to the petcock.  Gas should begin flowing out of the open drain screw. If yes, gas not a problem.  If no, then something is wrong in the petcock.
MP
"Ridin' with Cycho"
Valker
Wahoo!!!!
Texas Panhandle
« Reply #9 on: November 01, 2009, 04:10:40 PM »
Bob
Oh, Dang-that's what I meant earlier...kinked fuel line. I added a quick disconnect, made it just long enough to kink and not flow. Sorry for the "vent line' suggestion earlier.
Tomkat
« Reply #10 on: November 01, 2009, 04:35:25 PM »
Thanks guys.  Lots of things to check for.  I'll let you know what I find.  Thanks again for the help.  Tomkat
Tomkat
« Reply #11 on: November 01, 2009, 04:41:12 PM »
By the way with the cold start on it runs for about 5 seconds then quits.  Will not start with out the cold start.
« Reply #12 on: November 01, 2009, 06:49:52 PM »
Whenever mine sets for about 6 hours or more, I pull the choke on and  fire him up.............
Don't be afraid to use the choke, that is what it is there for.
Make sure ya got it ALL THE WAY on.......
When ya hit resistance, push harder, it should move some more.
The choke handle should be pointing directly across the tank to the other end of the handle bar. tickedoff 2funny coolsmiley angel cooldude
« Reply #13 on: November 02, 2009, 04:46:29 PM »
The bike WILL die if you leave it on full choke after it starts, just let it up a little bit after it starts, it will fast idle for a couple minutes, then release the choke fully and take off.  I'm old enough to remember manual chokes on cars, works exactly the same.  hoser
Tomkat
« Reply #14 on: November 02, 2009, 07:33:01 PM »
Thanks for the response Hoser.  Haven't had a chance to look at it today, but as soon as i take the choke off it kills.  I need to remove the tank and take another look to make sure everything is connected right and nothing is pinched.    Tomkat
HOZ
If it an't broke, don't fix it
Arlington, Wa.
« Reply #15 on: November 03, 2009, 09:53:18 AM »
I remember about 10 years ago a guy filled up with Diesel by mistake, would only run when the choke was on all the way, not good but did run enough to get to town. 2funny Took it to Honda shop in town and after a few hours trying to figure it out they finally smelled something funny. Emptied the tank and who would have thought it started right up. I know what you are thinking but this did happen and with about 30+ Valk riders around no one else had a clue what was wrong. Just  a thought.
VRCC #1555
98' Tourer (Black) 157,000mi
99' I/S (Green & Silver) 45,700mi
« Reply #16 on: November 03, 2009, 10:54:41 AM »
Not that this is your problem, its just the "no problem turning over" thing gets a lot of Valk owners.  The first classic sign of a weak battery on a Valkyrie is when it turns over strong but does not fire.  Just to remind you and anyone else.......if the battery was borderline and it sat for a few days, it may not have the power to run the ignition even though its strong enough to turn over the motor easily.......just sayin...... Smiley
« Last Edit: November 03, 2009, 10:57:09 AM by Chrisj CMA CR3M » Logged
« Reply #17 on: November 03, 2009, 01:09:16 PM »
To take all doubt out on a battery that is getting ready to poop, take a car battery, or pickup battery, MAKE SURE THE JUMPER UNIT is no RUNNING.
Hook up the bike battery & hit the starter.
If it starts, go get a new battery.
If it don't start, then start digging into why not.
Bike battery may have enough juice to spin the engine, but not enough juice to fire the coils and let it start.
Sometimes when you are letting off the starter they will start, same deal, go get a new battery.
Good Luck, cause I hate to chase these no starts also.
1st thing to check is the last thing ya screwed with in the electrical line.   Moving handlebars falls in this area also.
« Last Edit: November 03, 2009, 01:10:49 PM by R J » Logged
