February 14, 2026, 03:08:15 AM *
Author Topic: Thread Specs  (Read 991 times)
RipVanWinkle
« on: March 11, 2018, 05:48:35 PM »
Does anyone know what the thread specs are for the water temperature sensor and the oil pressure sensor are for a 99 standard?
I am adding gauges and am looking for metric adapters and need the thread size.
Thanks.
semo97
Texas
« Reply #1 on: March 11, 2018, 07:48:11 PM »
are you referring to oil pressure switch? book says PT 1/8. go to page 1-13 engine section, lubrication system, oil pressure switch, thread Dia. column did not see anything about water temp sensor. To me that is not metric it is standard 1/8 th. pipe thread.
sdv003
Prescott Valley, AZ
« Reply #2 on: March 11, 2018, 09:54:54 PM »
Motosens sells adapters for their gauges.   You might find the info you are looking for there.
« Reply #3 on: March 12, 2018, 06:57:59 AM »
If you speak German that's the way to go if they still stock the right parts.  I can't remember whom, but a couple of years ago someone tried to order stuff from them after the company changed hands, and they had to put in a fair bit of effort just to communicate with them.
I don't think an oil pressure gauge is needed, as oil pressure has never been an issue for Valkyries.  I installed a coolant temperature gauge from Autometer, and drilled and tapped the unused boss on the thermostat housing to use their temperature sender.
