February 14, 2026, 03:09:42 AM *
Author Topic: Rear Shock Replacement on 97 Valkyrie  (Read 1404 times)
JohnGil
« on: March 11, 2018, 07:34:17 PM »
All,
I recently became the owner of my dads 97' Valkyrie. I need to replace the rear shocks, and it
looks like there are 12" shocks on it now. I am a bigger guy (275lbs) and was wondering if I
should consider a larger shock. I am looking at the Progressive 412 Series.  Thoughts?
John
blackbird239
My 2002 Valkyrie
Philadelphia, Pa
« Reply #1 on: March 11, 2018, 07:56:29 PM »
Hi. A few years ago I upgraded to the Progressive 430 shocks. The standard size shock is 13 inches. I asked for 12 and a half. I am 5'7" and about 210lbs. I am very happy with them. They have an adjustable preload. It is done by hand. I am happy. Good luck.
« Reply #2 on: March 11, 2018, 09:36:40 PM »
I agree with going to 13" shocks. With your weight, you need the suspension travel and HD springs. I think the 412's might be too weak for you. Look into Works Performance shocks. They build the shock valves and springs for you.
JohnGil
« Reply #3 on: March 12, 2018, 12:35:24 AM »
It seems the bike comes standard with 12" shocks, Amazon is telling me the 13" shock will not fit the bike. I cant imagine why, it would seem I will just need to compress 1" of spring to install it.
Am I correct? or is it physically a larger dimension?
« Reply #4 on: March 12, 2018, 03:38:39 AM »
I'm not sure what Amazon is telling you.
Unless you can't touch the ground, I think you should get 13 inch shocks.
I would never get 412s, it would be better to find some used OEM shocks
that aren't worn out.
Sandy mentioned Works Performance...  cooldude
« Reply #5 on: March 12, 2018, 04:22:00 AM »
With the bike on a lift you can remove both shocks (support the swing arm with a strap and then install any length shock with no compressing anynthing
« Reply #6 on: March 12, 2018, 06:45:20 AM »
Agreeing with ChrisJ CMA, but I just lift the bike barely enough to unload the shocks and no more.
Any shock that fits an Interstate will fit a Standard or Tourer, so check for Interstate fitment.  You could physically fit 15" shocks, though they would be terrible for U-joint life and would change your steering geometry.
« Reply #7 on: March 12, 2018, 09:05:57 AM »
Wrong on size per Amazon, stock is 13"....not 12".  Just because you're heavier doesn't mean you need longer shocks, just stronger. Get some heavy duty meant for an I/S, they're built with a stronger spring. I've had 12" Progressive 412's on my Tourer for quite a few years and changed the springs over to the HD version to support both me and any load I choose to carry. Rather than send the shocks to the factory to have different springs installed, I built a homemade shock compressor and took me less than 30 minutes to remove the light springs and install heavier ones.
Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
« Reply #8 on: March 12, 2018, 11:54:20 AM »
I've had 12" Progressive 412 HD's on my IS for about 8 years now with no issues hauling myself, passengers, and luggage.
« Last Edit: March 12, 2018, 11:55:51 AM by Houdini » Logged
« Reply #9 on: March 12, 2018, 01:11:06 PM »
I'm same weight as you.  After much experimenting, I've found Progressive 444-4057's are perfect for me. 13" length, 140/200 springs.  Works for me, alone, with 130# passenger, and/or pulling a heavy trailer.  444's are more spendy than 412's, but definitely worth it IMHO.
Here's a thread from last year on the subject.  http://www.valkyrieforum.com/bbs/index.php/topic,96862.msg962579.html#msg962579
