January 30, 2026, 12:21:39 AM *
Author Topic: pilot screw question  (Read 2246 times)
deez
Builder of the Locost Seven on Steroids
Lee's Summit Mo.
« on: November 01, 2009, 04:02:30 PM »
I haven't fully traced through the carb circuits yet. Is the pilot screw an air bleed screw (shutting it down decrese air entering from the air bleeds, thus enriching the mixture , or are they fuel limiting screws, controlling the amount of fuel going through the slow jets( shutting it down decrease the fuel flow, thus leaning the mixture?
Pete
« Reply #1 on: November 01, 2009, 05:22:43 PM »
The general rule is that a pilot screw before the slide controls air, after the slide controls fuel. Since the Valkyrie pilot is after the slide it controls gas. Open more richer, less leaner. Good luck Pete.
« Last Edit: August 27, 2010, 10:28:43 AM by Pete » Logged
fstsix
« Reply #2 on: November 01, 2009, 05:40:04 PM »
Out is rich in is lean as above post, Good question sudco is not detailed on this topic. here is something i found might help.http://www.factorypro.com/tech/carbkei.html
Pete
« Reply #3 on: November 01, 2009, 05:42:00 PM »
" pilot screw between" should have been BEFORE. Sorry Pete.
« Reply #4 on: November 02, 2009, 11:25:11 AM »
fuel circuit only, no air bleed adjustment, as far as I know carbs w/air bleed screw adjustment were phased out industry wide back in late '69. air flow is controlled by the constant velocity slide.
deez
Lee's Summit Mo.
« Reply #5 on: November 03, 2009, 04:15:26 AM »
thanks for the input !
