Need carb installation help
Dave Weaver:
I have it in the bike, but it just doesn't look right. The middle of it (where the hump is) is sitting on the radiator hose where I think it belongs and the left (driver's) side looks ok, but as I said in original post, the right side is sticking out and almost hitting the horn. I cannot seem to get it back into where I think it should go as it is one solid plastic piece and the middle is resting on the hose. I think I will remove it and the carb bank, then install it without the carb bank to see how it is supposed to fit.
DFragn:
Quote from: Master Blaster on March 08, 2009, 04:35:18 PM
None of the blower bikes use it, and the heat isnt that bad. I dont think you will miss it too much if you leave it out. Saying this, I just installed a new engine with carbs on my exblower bike and put in the shroud. wasnt much of a problem, but I did have the radiator off.
Yup, but that wouldn't help much unless of course your top radiator hose hadn't been installed yet.
Navigation
[0] Message Index
[*] Previous page
