Exhaust Toys
<< < (3/8) > >>
Big IV:
Since you're running a truck stack more so than a motorcycle accessory bit, go to the local to you supped up honda car shop (where they are putting on the lambo doors and supersized wheels) and ask what they have in tips and accessories. Might be able to find something that a mini-trucker has ordered but not picked up yet that they'll make you a deal on.
Might find some other idea there that would work.
rmrc51:
I'll modify this post with Pilot pics one of our European members posted after he fitted the Pilots as soon as I find them and a link.
Rytek Fitment = O.D. Flush
Pilot tip link: http://spoilers4less.com/plt-pm-573.html
UPDATE:
Here's 3 "Pilot" Tip pics. As you can see the O.D. of the tips will fit the I.D. of the 4" stacks.
This member slid the extension in too.
I would seperate the extension from the tip for a flush mount or use the extension to 'trombone' any position you like.
You could always secure them in a flush position. That wouldn't look bad at all...
Pilot 1
Pilot 2
Pilot 3
Regarding the tips that are shown in the link you provided ( Pilot tip link: http://spoilers4less.com/plt-pm-573.html ).  Are these the same tips that are in the additional pictures you just posted above?
If so, I'll buy the set and install them in the same manner by sliding them in. Seems to be a fast, easy and relatively inexpensive solution.
DFragn:
to the best of my knowledge.
You might want to drill and tap some set screws to hold them in.
rmrc51:
Sounds like a plan! Thanks.  :cooldude:
Big IV:
might I suggest a little lock tite?
I remember the fish tail inserts falling out of an Indian I was test driving years ago. The factory rep said that never happened, yet they carried quiet a big box of them. I remember thinking, "lock tite is good."
I wonder if the high temp causes problems?
I used lock tite on my xs11 when I made the custom pipes, don't remember it ever causing a problem. But then again, I never took them apart afterwards either, I left them attached to the headers and moved them as a whole forever.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
