A question for Everyone who pulls a trailer with their bike
PAVALKER:
Quote from: Master Blaster on April 27, 2009, 11:33:28 AM
You wont need a swivel, regular tongue and ball works fine. Shouldnt be too hard to rig for safety chains. Ask Psycho what may happen if you dont use them. I think it wouldnt be much trouble to weld a couple of loops each sideof the reciever, or even under it.
Correct, you will not need a swivel hitch. I use the Hitchdoc Hitch and a HF trailer. The Hitch should have a hole under the fender where you can place an EYE BOLT (eye facing down) and attach your chains to the EYE. I use one ring for both chain ends and twist the chain and hook the ring to the eye bolt. The ring is actually a chain link with a nut on it that you can open/close the link.
sandy:
The HitchDoc has 2 holes under the hitch. I bolted two eyes there and hook my chains to them.
nortman:
at the hitch under the fender and found the holes for the eye bolts. Thanks again everyone :cooldude:.
Navigation
[0] Message Index
[*] Previous page
