Kentucky Memorial Weekend
Started by Smokinjoe-VRCCDS#0005, Fri 03, May 2013, 06:56:49
Previous topic - Next topic
Friendly reminder to everyone going on this ride.... Have the gas tank FULL & tire pressure checked before we leave out on the ride..... McDonald's is next door and Waffle House is across the road or you can score a donut at the motel for breakfast.... The motel coffee SUCKS .... The RaceTrac Market in front of the motel has much better coffee but its no Starbucks either.
robin
 :cooldude: :cooldude: :cooldude: :cooldude: How much pressure do i need?
Quote from: robin on Sun 12, May 2013, 06:56:52
:cooldude:
Tire Pressure Chart
The tire pressure you run depends on the conditions where you ride and the size of your tire. The following chart highlights the minimum and maximum rated tire pressure for each tire.
Important Notes
Don't run pressures higher than the number listed on the tire or in this chart as it will lead to a rough ride and may lead to the tire blowing off of the rim. Don't run pressures lower than those listed in the chart as this may lead to pinch flats. Fully loaded bikes and heavier riders should ride closer to the higher ranges in these charts. If you do not understand the information in this chart
Lawdog
An armed society is a polite society. Manners are good when one may have to back up his acts with his life.
Robert A. Heinlein
Medic
Hey all -
Unfortunately, due to being assigned to a class at work that will seriously be burning through some of my OT and finding out this weekend that I have to replace my central A/C unit in the house...I have to cancel this year. I just called and released two double rooms that I had booked at ground zero (Landmark)...so if you want a room there, two just opened up!! Hate to miss it...Joe and Don put on some awesome rides!
