News:
Main Menu
front tire...Shinko???
Started by slider, Mon 20, Feb 2017, 11:06:01
Previous topic - Next topic
interesting reading up on rear tires put on front installed in reverse arrow pointing.  I assume the michelin commander II rear tire installed on front would be same direction then as the michelin active pilot?
I guess I should do a search since I thought a long while ago someone posted on here that they ran a michelin commander II rear tire on the front?  Either michelin rear tire should work right?
decisions, decisions soon?   :roll:
DarkSideR
#41
Quote from: cookiedough on Tue 28, Feb 2017, 16:58:23
It's quite simple. I took my front wheel off today to get it ready for the new tire to be mounted. I put both tires together side by side with both arrows pointing forward in the same direction. I then looked at the tread pattern and noticed it was backwards on the new tire. So I spun it around and the tread pattern matched. This is why rear tires are run backwards on the front.
2001 Valkyrie Super Tourer
VRCC#34410
VRCCDS#0263
Also, the written word on this subject talks about cord/belt stacking under hard breaking if you don't run reversed.
I ran mine reversed.
When I had it put on at the shop, their lead tech confirmed rears on front should be reversed.
Quote from: Jess from VA on Tue 28, Feb 2017, 21:28:30
good to know, now to decide on what tire to install in front before April comes???
Just replaced my front Shinko Journey with a new one.
9,500 miles of mountain riding.  :cooldude:
Nice even wear across the tire at a constant 42psi.
