If you have a male "lighter socket type" auto cord for your GPS then yes, that amazon socket will plug into your Garmin-type polarized connector and you're all set. If your GPS also has a USB cord for charging, then you have your choice. One thing to remember is most GPS units run on 5volts DC, so the "car socket charger" power cords will have a 12>5v voltage reducer built into the cord. It's usually in the actual plug, but some early ones were in the cord, like a snake swallowed a tennis ball. Some folks run into trouble because they decide to cut off the bulky lighter-type plug and hardwire directly to the bike. POP! They've cut off the voltage reducer and wired a 5v device to a 12v bike
