November 14, 2025, 08:53:57 AM *
Author Topic: IS radio manual  (Read 477 times)
longrider
Vernon, B.C. Canada
« on: September 12, 2018, 03:00:43 PM »
I found basic instructions in the owners manual.  I would like to access the aux input if I can but don’t know which input it is behind the side cover
Dusty
Mill Bay B.C.
« Reply #1 on: September 12, 2018, 03:26:25 PM »
 Warren
There is a connector in the right sides cover comes from the top in front of the battery. About 1/8 " diameter cord with a RCA ? connector with a rubber cap on the end. The other small wire connecter is for an antenna. Plug your aux feed in and your good to go.
Dusty
« Reply #2 on: September 12, 2018, 03:50:11 PM »
Warren
Dusty
yep, is hard to find but is there you will find it eventually amongst all those wires.  A cheap AUX jack cord for say mp3 player, etc. say 4 feet long is good to run up under the tank into say what I have is an iron horse tank bib on my gas tank that holds my cheap mp3 player.
Just an fyi,  once you figure it out,  your music device such as mp3 player has to be CRANKED volume all the way up as well as the radio volume control on your Interstate left handlebar anywhere between 15-22  setting to hear it decent while riding.    I love the auto volume control set on HI, works well as speed increases your volume automatically increases and works well, as you slow down the volume goes lower which is nice since less rpms from motor do not need louder volume then at slower speeds.
« Reply #3 on: September 12, 2018, 04:37:45 PM »
Search is your friend, was the 1st link that came up and the pictures are still there.
http://www.valkyrieforum.com/bbs/index.php/topic,26484.0.html
« Reply #4 on: September 12, 2018, 04:58:29 PM »
Warren
Dusty
I have polk speakers and an amp so I have to keep my device volume no more than 75% and bike volume at 20 tokeep it from distorting. I also use a bluetooth adaptor that plugs into my battery tender plug.
