April 01, 2026, 02:14:14 AM
Interstate Fog lamp Bulb #
Topic: Interstate Fog lamp Bulb # (Read 1625 times)
moreira72
VRCC# 33494
Clark, NJ. 07066
October 21, 2018, 08:57:55 AM »
I would like to replace the fog lamp bulbs in my pods with LED bulbs. anyone know the bulb #? H7, H11 etc.? I replace them on another I/S years ago, but can remember the bulb number. TIA
moreira72
VRCC# 33494
Clark, NJ. 07066
Re: Interstate Fog lamp Bulb #
October 21, 2018, 12:47:06 PM »
found it on the installation instructions. H13 Bulb
Bagger John - #3785
October 22, 2018, 07:24:21 AM »
Add-On makes a set of LED fog/running/signal lamps for the GL1800s. I'm going to buy a set, see if I can make them work mechanically then figure out a wiring harness update and post details when done.
SCain
Rio Rancho, NM
October 22, 2018, 11:07:50 AM »
I haven't heard of an H13 bulb, Mine are H3 bulbs in both my Interstates, I just switched one of them to LED's, bought them off of Amazon, there was a thread on here not too long ago about LED bulbs for the IS Fog Light. I think these are the ones I bought.
https://www.amazon.com/Calais-Bright-1200LM-Lights-Plug-n-Play/dp/B01CTMTATI/ref=sr_1_1?s=automotive&ie=UTF8&qid=1506190948&sr=1-1&keywords=led+h3+bulb
Last Edit: October 22, 2018, 11:10:41 AM by SCain
Steve
pocket aces
Tampa, Fl
October 22, 2018, 11:22:08 AM »
Yep that the set I bought also for my Interstate. I have had them in for a year, trouble free.
moreira72
VRCC# 33494
Clark, NJ. 07066
October 23, 2018, 10:14:05 AM »
thanks for the link. I ordered a set from amazon. the Honda fog light kit instructions had them as H13. must be a typo on Honda's part.
Savago
Brentwood - CA
Reply #6 on:
October 24, 2018, 01:06:36 PM »
I have being using Hella H3 bulbs, they are good and cheap:
https://www.amazon.com/gp/product/B00IKM60M2/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
kodiakfisher
Beaverton, OR
Reply #7 on:
October 24, 2018, 06:11:30 PM »
Be careful when selecting your fog lights. The higher the kelvin rating the less contrast you get between the fog and the road because the color of your light matches the fog so no contrast is created.
I have a 7500 kelvin headlight and 4000k fog lights so when I do turn on my fog lights in the fog I get some contrast.
https://www.amazon.com/gp/product/B06WGSKTRZ/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Doug E
NighthawkVTX
Gainesville, Fl
Reply #8 on:
October 28, 2018, 09:11:23 AM »
So do I have to remove the entire pod to gain access to the bulb?
If at first you don't succeed, then perhaps skydiving isn't for you
Forge
San Antonio, TX
Reply #9 on:
October 29, 2018, 04:56:49 AM »
Quote from: NighthawkVTX on October 28, 2018, 09:11:23 AM
Yes, the pod comes off and then the light assembly. The bulb is accessed via phillips/JIS screws on the back plates of the light assembly.
