March 26, 2026, 05:42:01 AM *
Author Topic: Final drive reinstallation steps and maintenance details  (Read 4124 times)
« on: October 21, 2018, 04:49:44 PM »
We talk a lot about re-installation steps and necessary maintenance
details for the Valkyrie's final drive.
What follows are my attempt to summarize Honda's instructions. Honda has
specific service manuals for each bike and also a Common Service Manual.
To follow this in the service manual, you have to skip around. You
might be following the Final Drive Installation instruction steps
and come to a step that says "install the rear wheel (page 14-8)"
for example. The Honda manual doesn't just have steps for
removing the final drive and reinstalling it, the manual's steps
include rebuilding it while it is out so you have to connect the
dots for the steps you skip.
 - new stopper ring on the pinion cup end of the driveshaft
 - new seal
 - .5 grams of grease onto "the splines"
                 The Common Service Manual says the .5 grams of grease
                 goes into the seal's lips. The diagram in the Valkyrie
                 service manual also has the grease arrow pointing at
                 the seal's lips.
                 I weighed out .5 grams of grease
                 and found the resulting amount to be
                 interesting. Surely all grease does not
                 weigh the same.
 - reuse the spring, washer and snap ring
 - 2 grams of grease in the pinion cup splines
 - 1 gram of grease on the driveshaft splines on the u-joint end
                 At this point the left side lower shock
                 bolt is already on and torqued.
 - install the final drive, getting the right side lower
   shock bolt in and also "the four nuts" on their studs
 - torque the four nuts
 - put moly paste in the o-ring groove at the damper plate on the wheel
 - install a new moly-paste-coated o-ring
 - coat the mating surfaces on the wheel and the underside of
   the flange with 3 grams of moly paste
 - coat the thrust washer with moly paste
 - plug the flange into the wheel with the thrust washer in place
 - put moly paste in the o-ring groove on the flange
                 Honda's procedure for installing the final drive
                 comes right after their procedure for rebuilding
                 the final drive. The elusive 3rd o-ring and it's
                 groove's moly paste treatment is similar to the other
                 two and is outlined in the rebuild procedure.
 - put 3 grams of moly paste on the flange splines
                 The accompanying picture seems to indicate
                 paste on both the splines on the flange and
                 the splines in the final drive
 - put 1 or 2 grams of moly paste on both mating surfaces
   of the final drive and of the flange where the flange o-ring
   seats onto the final drive
 - loosen "the four nuts" to ease axle installation and to
   assure proper flange alignment
 - put the wheel up in there (mate the wheel to the final drive)
 - install the caliper (but not the stopper bolt)
 - install the axle
 - install and torque the caliper stopper bolt
 - install and tighten the axle nut
 - tighten "the four nuts"
                 The Common Service Manual indicates to do the
                 tightening of "the four nuts" in a criss-cross manner
                 in several steps until the proper torque is reached.
 - tighten the lower right shock bolt
We all have things we do and ways we do it that are outside
the scope of these steps. I take my rear fender section off, I
probably saw Daniel Meyer do it that way at Johnson City. I take my
shocks off and I use a turnbuckle for a swingarm holder, I got
the idea for a swingarm holder from Jeff in Florida. I sink and
raise my bike on the lift to get at the axle and so that I can
just roll the wheel out after the rear fender section is off.
« Last Edit: October 21, 2018, 04:55:06 PM by hubcapsc » Logged
« Reply #1 on: October 22, 2018, 04:20:22 AM »
Cool report Mike cooldude
I'm wondering what those twins things under the swingarm are?
« Reply #2 on: October 22, 2018, 04:26:38 AM »
Thanks... It was fun writing it out as a bullet list and cross referencing
with the Common Service Manual...
Under the swingarm is BigBF's quad horns... they've been on there
since the 2nd Johnson City...
Punisher
No, not vengenance. Punishment.
« Reply #3 on: October 22, 2018, 05:19:26 PM »
Nice write up. Wonder why they want you to torque the 4 nuts then later loosen them when putting the axle through?   I just push the final drive all the way up and run the nuts up finger tight, torque the axle then tighten the nuts.
Need to wash up in that rear fender  cooldude
Dont scratch up my Cobra fender rails  Cool
Don't forget to blow your breather channels out for that swing arm.
« Reply #4 on: October 23, 2018, 05:03:09 AM »
This is the tech board, not the fantasy board  coolsmiley
doubletee
VRCC # 22269
Fort Wayne, IN
« Reply #5 on: October 23, 2018, 05:12:15 AM »
Breather channels? What/where are those?
« Reply #6 on: October 23, 2018, 05:58:35 AM »
http://www.valkyrieforum.com/bbs/index.php/topic,90423.msg892531.html#msg892531
« Reply #7 on: October 23, 2018, 01:37:39 PM »
I thought that was the ant home.  Smiley
ValkStrom
Westerville, OH
« Reply #8 on: February 23, 2019, 03:51:05 PM »
I just finished up my full final drive service, I know it was never done by the original owner and that the dealer never did it. Now my girl only has 7200 miles on her, but I was very pleased to see just how much grease/lube was everywhere it needed to be. The pinion cup was even lubing the drive shaft gear with final drive lube like Honda intended. All the splines look like new everywhere, so that was a relief for me to see. I did a full change of the final drive fluid, even though it was reportedly done a few years back by a dealer. Rear wheel moves like warm butter, not so much as a single sound I'm hearing anywhere. Exhausts are still completely off, that really made everything so easy to access and torque. Took all the exhaust shields off, underneath was a mess and all the bolts are very rusted. I am powder coating all the shields ink black, and now I can really clean up the exhausts and headers before I put everything back on. Thanks so much for all the great write ups and advice here......y'all rock!!!!  Cool
97 yellow/black custom, 15 V-Strom 650XT
« Reply #9 on: February 23, 2019, 04:49:05 PM »
Made me laugh.
