How do you guys stockpile large amounts of ammunition without creating an extreme fire hazard? If your house caught on fire would the fire dept even fight the fire upon learning you have a large ammo cache in the fire? .....and they WILL ask.
. You realize ammo wont just shoot a bullet out the end without it being chambered in a barrel right?
if ammo does get hot enough to ignite the powder inside the case it will most likley split the case at the neck and the bullet goes nowhere. You have to have that chamber so the pressure has nowhere to go but out the barrel. Educate yourself, don't believe what you see in movies.
