« Reply #1 on: April 11, 2021, 03:34:20 PM » |
Also, these two were posted - both yellow and black. First one is from Australia.   Edit - And this one from Australia, also yellow and black (apparently they made Aussie models in '96)...
« Last Edit: April 11, 2021, 04:38:11 PM by f6gal »
« Reply #2 on: April 11, 2021, 04:17:18 PM » |
Made me go look at mine. It was made in 12/96. They had all the bugs worked out by then  ... -Mike
« Reply #3 on: April 11, 2021, 04:26:40 PM » |
Made me go look at mine. It was made in 12/96. They had all the bugs worked out by then  ... -Mike So your serial number is between 003431 and 003471?
« Reply #4 on: April 11, 2021, 04:37:25 PM » |
3437 is part of that great big number... is that the only part that is "the serial number"?
« Reply #5 on: April 11, 2021, 04:52:04 PM » |
The SN is the last 5 digits. The other numbers and letters in the VIN indicate various things like model, destination country, model year, etc. 1HFSC340(?)VA003437
« Last Edit: April 11, 2021, 04:56:25 PM by f6gal »
RP#62
« Reply #6 on: April 11, 2021, 06:40:45 PM » |
Thanks Connie. I'm still tracking them, just maybe not as diligently as I used to. I'll add these to the database. At some point I need to update the VIN artlcle as I've added a lot to the database since the last revision.
-RP
« Reply #7 on: April 11, 2021, 06:43:35 PM » |
-RP
What's the lowest number you've come across?
RP#62
« Reply #8 on: April 11, 2021, 09:00:19 PM » |
The lowest numbers I've seen are: 49 state standard: 1HFSC3406VA000006 (a red & white model) Calif standard: 1HFSC3413VA000005 (a black model) Canadian standard: 1HFSC3422VA000120 (a purple and white model) well, until your post anyway 49 state tourer: 1HFSC3438VA000003 (a green and cream model) Calif tourer: 1HFSC3447VA000003 (a green and cream model) Canadian tourer: 1HFSC3452VA000001 (a green and cream model) European (except Ger & Swiss) standard: 1HFSC34A8VA000128 (a red & white model) German standard: 1HFSC34B8VA000428 (a red & white model) Australian standard: 1HFSC34U5VA000002 (a yellow & black model) 49 state interstate: 1HFSC4101XA000007 (a black model) Calif interstate: 1HFSC411XXA000032 (color unknown, but probably green & silver) Canadian interstate: 1HFSC4121XA000008 (a green & silver model) Australian interstate: 1HFSC41U0YA100023 (an orange & black model) Japanese standard: SC34-1000002 (a black model)
-RP
