May 02, 2026, 01:06:39 PM *
Author Topic: Different mirror postions  (Read 2896 times)
Tx Bohemian
Victoria, Tx
« on: January 21, 2010, 02:20:16 PM »
Does anyone know if there is a different shaft design for mirrors?
I'm thinking if the shafts on the mirrors came up from where they mount on the Handlebars and instead of turning outward, turn forward for an inch or two then outward.  This would position them farther forward and you wouldn't have to turn your head much at all to see through them.
Or am I just being lazy?
Al
« Reply #1 on: January 21, 2010, 04:25:45 PM »
A major problem with (most OE) mirrors is individual height.  Taller people really need taller mirrors.  Yes, they can be angled, but then you are looking down too much, instead of glancing a little sideways.  I had been running Kuryakyn large magnum convex with tall stems, but one side could not be adjusted to my satisfaction without turning the controls on the bars which I did not want to do, so I put the boxey/fugly OEs back on.
My other valk came with OE Yamaha mirrors (or knockoffs), but the stems on these can be turned catywumpus so the mirrors go almost straight up from the bar, and even though the teardrop mirror is smaller than the OEs, they work better for me than any other.  HDL sells a set of Yamaha style teardrop knockoffs for a reasonable price, and I have been considering ordering to see if I can get them set up the same as on my other bike.  I am not sure if these will work like the ones on my bike, but this is them.
http://www.hondadirectlineofshadyside.com/stores/product.asp?pid=4434&str=2&ID=180380195
And watch out, some of the extra long stem mirrors out there are for drag bars, and the added length is OUT not UP.   IMHO getting the mirrors taller is the solution for most people unhappy with theirs.  What gripes my azz is there are hundreds of stupid tiny, chromy, squiggly, dentist mirrors out there, but very few decent functional mirrors for real riders.
Thunderbolt
Worthington Springs FL.
« Reply #2 on: January 21, 2010, 05:58:53 PM »
and she likes it that way.  Just loosen the nut where it attaches and spin around.  Of course you also need to readjust the actual mirror itself, just flip it around after loosening the adusting nut.
As you said, you don't have to look so far out, although you do see your shoulders.
I installed some aftermarket mirrors on the Interstate and added some mounts that clamp on the bar and moved them in also.  J&P cycles sells the mounts.
ricoman
Sarasota, FL
« Reply #3 on: January 22, 2010, 04:26:29 AM »
I got a pair of mirror "risers" from a guy in New Zealand-can't find the order/link but will keep looking.
They are machined out of aluminum and thread into the mirror mount, then the mirror threads into them.
Raises the mirrors a bit over an inch-no more looking down, at least for me.
If your mirrors are properly adjusted you will not see any part of yourself in them.
Mirror use is too often forgotten a a major safety tool. Anytime I hear of a bike being rearended I wonder why the heck the rider wasn't using this tool. Should look in them at least once a minute when riding.
PharmBoy
Lawton, Ok
« Reply #4 on: January 22, 2010, 07:24:27 AM »
Most all mirror stands now have a 10mm right hand thread (except one on the Yamaha is left hand threaded).  I bought these over sized mirrors about two years ago and turned the stands around so they are taller instead of wider.  I don't remember what they cost, but I know that I was surprised at the quality for the price. The stands alone would have been worth the price.  Ken Sean makes a good mirror for the price and I know that some of his mirrors have the bend much closer to one end than the other.  Maybe you can get a better idea from a picture.  (Please excuse the bugs!)...JTL
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
PharmBoy
Lawton, Ok
« Reply #5 on: January 22, 2010, 08:09:36 AM »
I am pretty sure that this is the mirrors that I purchased and have been well satisfied with the larger mirrors and the position of them after turning the stem around...JTL
http://cgi.ebay.com/ebaymotors/Honda-VTX-1300-C-S-R-T-new-chrome-BIG-MIRRORS-pair_W0QQitemZ370323846458QQcmdZViewItemQQptZMotorcycles_Parts_Accessories?hash=item563905753a
99 Interstate
97 Bumble Bee
97 Red & White
