March 26, 2026, 04:16:24 PM *
Author Topic: Interstate radio needs repair. Anyone out there?  (Read 2723 times)
Danny Dove
« on: January 29, 2010, 11:16:40 AM »
 I have a 2000 Interstate. Last year the alternator rotor shorted out and killed my radio at the same time. I wonder if there is anyone out there who does repair work on these things. I have replaced the main radio diode, all fuses are good, and I have checked for power coming in to it. I even opened up the unit to see if I could see anything burnt. All looks OK. Used radios are ~ $350 on e-bay and new ones are OUTRAGEOUS. Help, I miss my tunes.
1fastbob
South Central Kansas
« Reply #1 on: January 30, 2010, 05:22:46 AM »
Quite a few years ago I worked on things like this.  I would open it up and see if there is a protection diode inside the case near the power supply input.  If there is and it is open or burned you may get by with a very inexpensive fix. If not a new radio might be required.
If you do open it feel free to take a photo and send it to me.  I would be happy to look at it for you.
Hope this helps.
Bob
I'm on somebody's list! BFD!
Danny Dove
« Reply #2 on: February 02, 2010, 07:15:59 AM »
Thanks, I haven't known what to look for, I will take a look and see. I'll let you know what I find. Smiley
« Reply #3 on: February 02, 2010, 07:47:13 AM »
You don't mention where you are located, which would be important if wanting to take it to a shop.
Rob A
Vancouver, WA
« Reply #4 on: February 02, 2010, 08:06:32 AM »
Sierra Electronics repairs Goldwing radios so they should do Valk Interstate Radios, They might be the same radio.
Here's the link
http://www.sierra-mc.com/
1999 Interstate
« Reply #5 on: February 03, 2010, 12:42:43 PM »
Hope this helps.
Bob
Like 1fastbob said, most likely the diode. What is your level of electronics experiance? I just have my high school classes, and have been doing home electronics for years now. Do you have an electrical meter for testing and know what a diode is and looks like?
Friagabi
Tacoma, Wa
« Reply #6 on: February 03, 2010, 08:03:26 PM »
I also ride a 2KIS. If anyone can supply the CD interface specs. I would be grateful.
Danny Dove
« Reply #7 on: February 15, 2010, 11:19:45 AM »
I'm not great with electronics but I think I can find the diode. I do have a meter to check things out. I have a strong background in electrical circuits but weak on electronics. I live in the Houston area. Has anyone tried aftermarket radios on a Valk? Sorry I haven't had any spare time to check anything out yet, life has been very hectic.
Friagabi
Tacoma, Wa
« Reply #8 on: February 15, 2010, 05:00:55 PM »
Mine died several years ago. Diagrams are available in Shop Talk. Check that all input voltages are there. The dash module also has 12 volts on it if I remember correctly. Mine died due to a bad wire in the harness to the display. One of those sometines it worked and sometimes it did not. I just ran a wire on the outside of the harness and it has never acted up since. The radio has a standing 12 volts on it to keep the clock on time and switched 12 volts to turn it on and off.
sergbutton
Eldersburg, Maryland
« Reply #9 on: August 14, 2012, 08:30:32 AM »
I have not been able to find a Radio specific Diagram for the IS.
I have had my radio apart to look for obvious connection problems, but I do not know where the diode is.
Can any one take some photos of the things that I should look for inside the radio.
« Reply #10 on: August 14, 2012, 05:12:12 PM »
Go to the Gold Wing board. GL1800riders.com and do a search for radio repair. There's a guy who repairs and upgrades wing radios.
