April 05, 2026, 06:09:11 AM *
Author Topic: Hydrolock  (Read 939 times)
calcruiser
« on: March 23, 2026, 11:31:35 PM »
I've been digging through old threads some on the issue and can't find the answer.   Question I have is how is it possible with the stock vacuum operated petcock?  Is this problem only on valks with a gravity petcock swapped in?  Or is it the gas already in the fuel line that gets in the cylinder and that's enough to lock it up?
da prez
Wilmot Wi
« Reply #1 on: March 24, 2026, 01:14:50 AM »
  The fuel is leaking thru the carbs.  Usually on the left side as it is the parking lean. Petcock may or may not be faulty. The carb float needle is not sealing.  It does not take a lot of fuel to hydro-lock. Liquid will not compress.
  Petcock ,disconnect the fuel line. In on position , no fuel should run. If it does , faulty . Apply vacuum ,fuel should flow. Release vacuum fuel should stop.
  When I buy a bike that has been sitting , I remove front center cover and ratchet wrench the engine over at least three full turns. If it will not turn , spark plugs come out. Turn over by hand a few turns and then try the starter. I put a towel over the plug holes as fuel will shoot a long way.
                                                 da prez
DIGGER
« Reply #2 on: March 24, 2026, 09:49:37 AM »
I trailered 280 miles to my sons ranch last summer.  When i got there the Valkyrie was hydro locked. Pulled the plugs and hit the starter.  I didnt know about the gas shooting a long ways and got a load of high speed gasoline right in the eyes.  I was by myself and blinded with very murky vision and pain and literally crawled inside and flushed my eyes and face for a long time.  The rest of the weekend my eyes were scratchy and sun sensative.  When I got home I went next morning to my eye doctor and got his blessings that my eyes should be ok in a few days.  Close call.
« Reply #3 on: March 24, 2026, 11:40:50 AM »
this is from Rider mag sept 1988 about the '88 goldwing Gl1500.
they had the hydro-lock problem and it turned out to be the bowl vent hose was sagging. "the low spotfills with gas and prevents air circulation, much like a sink trap. without a connection to atmosphere, the float bowls pressurize and raw fuel is forced up and out of the carbs through the needle jet. From there gravity takes the fuel down the intake runners. if that cylinder has an open intake valve, hydrolock." "The article states that honda issued a Product Update kit on a fix in feb of that yr which included a metal air-vent pipe which kept the vent hose from sagging and a vacuum fuel valve."
Looking at the service manual pics in the carb section it shows the vent hoses as straight sections just laying loosely on top of other hoses. My 98's vent hoses have a 90 degree end. the end is installed into holes in the rear carb support frame.
or the bowl vent and overflow tubes have critters nesting inside blocking airflow.
« Reply #4 on: March 24, 2026, 01:37:10 PM »
Very similar to what happened to me.  Trailered to FL, unloaded and went to lunch, no issues. Came out after and hydro locked.
Pulled the plugs, hit the starter, and covered my buddy. Luckily, the only real damage to my buddy was his shirt and pants getting gas soaked.
Still, he wasn't happy. Roll Eyes
The debate goes on if there is enough gas in the line south of the petcock to cause a lock.
I feel there maybe, but the petcock vacuum and the carb float jet systems need to be compromised, along with the intake value in the open position.
I try to remember to do a slight starter button first, quick half second push, but don't always do it.
calcruiser
« Reply #5 on: March 24, 2026, 04:36:46 PM »
All excellent replies, thanks guys.  I replaced petcocks on both my bikes with new oem, for some reason they are cheap and abundant, like $30 cheap.  Changing petcock made "Lorenzo" run way better.  My thinking was this problem was from a bad diaphragm in the petcock.  Thanks to this thread, i'm going to pull plugs if ever trailering before starting with a towel over the plug holes.  I really don't want this problem, never had it and hope never will.  Gonna try and get in the habit of the soft quick starter button push test.
Off topic.  I've noticed the market changing on Valks in Cali.  Just in the last year or so.  They don't last.  Prices are up too.  They sell fast here, and there's way fewer coming up.  Hang on to your Valks boys, they are gonna get hard to replace.  Cali is gonna gobble them up.
Mooskee
Southport NC
« Reply #6 on: March 24, 2026, 05:47:59 PM »
I get questions often about hydrolock, petcocks, and using a fuel solenoid.
I wrote the linked article to address the following issues:
•   What is hydrolock?
•   Petcocks.
•   There is a failure mode of the vacuum operated petcock that can flood the #6 cylinder.
•   Why Manual Petcock?
•   Some Manual Petcock Options.
•   Fuel Shutoff Solenoid with Relay Harness.
•   Modifying the OEM Petcock to remove the Vacuum Function.
Here is a link to the article. The article is also available for download on my website.
https://img1.wsimg.com/blobby/go/70754328-6fc6-422f-89c5-60bb891503fe/downloads/548298ba-75fb-41de-ae59-189312a6fb7b/Hydrolock%2C%20Petcocks%2C%20and%20the%20Fuel%20Solenoid.pdf?ver=1774375300231
« Last Edit: March 24, 2026, 06:03:46 PM by Mooskee » Logged
Pluggy
NC
« Reply #7 on: March 24, 2026, 08:07:55 PM »
Mooksie, we know a Valkyrie stock valve is a manual valve and a vacuum valve combined into one housing.  If an owner always turns that dual valve to "OFF", would that be just as reliable as turning the Honda manual-only valve to "OFF"?
A 1998 Owners Manual says set the selector to "OFF" only for stoage.  The 2003 manual says to turn the selector to "OFF" whenever the motor is off.  Maybe Honda learned something.
Mooskee
Southport NC
« Reply #8 on: March 24, 2026, 08:40:40 PM »
My understanding is if you eliminate the vacuum function by modifying the petcock as graphon rydr described, then it will function as you say. The stock one will turn off anyway, but can fail in a way that will allow fuel down the vacuum line.
The mod to to remove the vacuum function is simple. I have only done it with the petcock out of the tank however.
ridingron
Orlando
« Reply #9 on: March 24, 2026, 08:43:48 PM »
A 1998 Owners Manual says set the selector to "OFF" only for storage.  The 2003 manual says to turn the selector to "OFF" whenever the motor is off.  Maybe Honda learned something.
Or their lawyers said to to add it for CYA reasons.
« Reply #10 on: March 24, 2026, 10:33:27 PM »
Eliminating the vacuum function has no impact on the function of the "off" position of the OEM petcock. If one is uncomfortable with trusting the vacuum function one can certainly turn the setting to "off" whenever the bike sets idle.  That certainly should be done when the bike is being trailered.
ridingron
Orlando
« Reply #11 on: March 25, 2026, 02:12:49 AM »
If I were to trailer my bike, I would turn the fuel valve off, ride onto the trailer and run the bike until it died from lack of fuel.
DIGGER
« Reply #12 on: March 25, 2026, 09:29:20 AM »
Good idea
« Reply #13 on: March 25, 2026, 11:57:05 AM »
I've considered that plan but have wondered if having the floats bouncing up and down the whole trip would effect them.
Probably not, but they were most not likely engineered with that in mind.
It does seem to be the best plan available.
« Reply #14 on: March 25, 2026, 04:03:32 PM »
Actually, I believe the bouncing of the supposedly still petcock puts extra force on the vacuum closed gate while the bouncing of the floats contributes to their not fulfilling their limiting function.
I normally don't trailer.
LTD
« Reply #15 on: March 26, 2026, 12:11:29 AM »
I had a valkyrie hydrolock on me starting it up at a honda dealer on a used bike they were trying to sell.  It was quite a shock.
