April 28, 2026, 10:37:51 PM *
Author Topic: 55-watt H3 halogen bulb in a cobra light bar.  (Read 989 times)
mbramley
Painesville Ohio
« on: April 14, 2026, 03:03:58 PM »
  I tried doing a search on here and got some information. I have a light bar, pretty sure it's a Cobra brand. The light they put out is a yellow and not all that bright. I tried a set of LED bulbs that I found on a aftermarket motorcycle parts website. They were a nice bright white light but was kind of scattered. I went to the local parts store; they had either the yellow light 35 watt or 55-watt white light. I tried the 55-watt bulb, and it is definitely hotter just by feeling the light housing. I can't find a 35-watt white light bulb. Has anyone tried the 55-watt bulb over a period of time. My main concern would be wires drying out because of the temperature or over stressing the circuit.
« Reply #1 on: April 14, 2026, 05:51:22 PM »
yellow is more visible to cagers if u don't night ride
h13man
Indiana NW Central Flatlands
« Reply #2 on: April 15, 2026, 05:41:06 AM »
The halogen 55 watt, 4.6 amps per bulb. Our alternator's, 55 amp. output. I went with 10 watt LED spots on top of the engine guards (train effect appearance) @ 1.7 amps. while wired thru the low beam circuit. Had a Bon S current bypass but it has failed. Maybe replace the Cobra housings with new LED housing's?
