March 26, 2026, 02:34:10 PM *
Author Topic: Oil leak on new to me Valk  (Read 2178 times)
Full_Throttle
West Frankfort, Illinois
« on: July 03, 2010, 05:11:28 PM »
I am the proud owner of a '98 valk.  On the drive home I noticed an "oil" smell....burning oil.  After inspection I noticed oil residue on the left side exhaust.  I removed a few covers and tracked it down to the lower bolt holding on the alternator.  Before I go any further, I thought I would ask around.  Do you think this is from the alternator o-ring not functioning properly?  I have attached a picture for your viewing pleasure Wink
« Reply #1 on: July 03, 2010, 05:19:28 PM »
I can tell you that removal of the alternator will result in oil getting on the exterior surfaces in that general area.  It may not be a leak if the PO had the alternator out......did you try cleaning it off real well and then see if it leaks more?
houstone
Can't get enough...
Santa Fe, TX
« Reply #2 on: July 03, 2010, 07:12:50 PM »
And, check the shift lever seal.  Easy fix...only place mine has had an oil leak, and I've had the alternator out several times.  Don't ask, I live near Rocketman!  ;-)
« Reply #3 on: July 03, 2010, 08:02:34 PM »
WTF is that on the bottom bolt of the cam cover?  ???
« Reply #4 on: July 03, 2010, 08:04:26 PM »
Judging by the wear marks on the frame, i'd say it has been out.
Full_Throttle
« Reply #5 on: July 03, 2010, 08:49:18 PM »
I cleaned it and then let it idle for 5 min. and that is when I took the picture.
I went ahead and removed the alternator to find the o-ring was damaged and whomever was "in there" applied a lot of sealant in an attempt to avoid putting on a new o-ring Angry
Why they wouldn't put on a $5 o-ring is just laziness.  I will go get one and solve this little problem.
BTW the Valk has 30K miles.
CowboyBlue
Saint Louis, MO USA
« Reply #6 on: August 08, 2012, 12:29:04 PM »
I replaced my alternator with a 85amp new model from a a Wing. I rode it about 3K miles and just noticed that when it is about 100 degrees outside and I flog my bike, it will drip infrequently from the bottom of that bolt. I know the new alternator had a new o-ring. However, due to my inexperience when installing the alternator (it's actually easy if you follow the tutorial to the letter), I suppose I may have damaged it, or the chinese o-ring sucks. I will be removing it again this weekend and replacing the o-ring. I need to replace the rubbers inside anyway, as they had dislocated themselves. I ordered all new parts proactively. There can't be a leak from anywhere else on that side. It drips right straight down on the exhaust. Freaked me out when I smelled it. And Hondas don't leak...
