November 23, 2025, 01:48:55 PM *
Author Topic: another way to go with your key  (Read 2116 times)
ricoman
Sarasota, FL
« on: January 02, 2011, 08:14:46 AM »
Made a key cover using a grip end and JB Weld. I like it and no one (almost) knows what it is. On my old Valk (actually they are all "old") I used a zirc fitting just for kicks.
Used acorn nuts to holds keys on the LeatherLyke bags and left them in most of the time.
I hope to see some more ideas.
http://vrcc.photostash.com/vrcc_29849/key-switch%20005.JPGhttp://vrcc.photostash.com/vrcc_29849/key-switch%20006.JPG[/img]
ricoman
Sarasota, FL
« Reply #1 on: January 02, 2011, 08:44:09 AM »
two more
T-Bird
Cleveland, Tennessee
« Reply #2 on: January 02, 2011, 09:19:09 AM »
Smokin'Joe showed me that trick a few years back and I have done all my valks with the grip ends. I've often thought about trying to do something else, but like you said with the grip ends nobody knows what it is Wink
« Reply #3 on: January 02, 2011, 09:41:38 AM »
I made my first one in 1978 on a Honda 750....I've got a drawer full of them in the garage...Here's a couple shots one like you made.
And this one made from a chrome cabinet knob.
« Last Edit: January 02, 2011, 09:43:12 AM by Smokinjoe-VRCCDS#0005 » Logged
Marcel
« Reply #4 on: January 02, 2011, 10:16:54 AM »
I think I will make mine look like a cigerette lighter.
OldFatGuy
Southern Illinois
« Reply #5 on: August 12, 2015, 04:13:23 AM »
What if you made one to look like an ignition switch without the key in it? No one would know if you accidentally left your key in.   :p
ricoman
Sarasota, FL
« Reply #6 on: August 12, 2015, 04:20:13 AM »
now that is a good idea!
off to find an old switch
« Reply #7 on: August 12, 2015, 08:42:16 AM »
What is used as a filler/glue? I like the idea and have often thought of doing it, just never got around 2it!
ricoman
Sarasota, FL
« Reply #8 on: August 12, 2015, 08:50:31 AM »
I used JB Weld on one and a generic 2 part epoxy on another.
You may need to grind the key down to fit into the cap or whatever you use.
And be sure to measure/check the fit into the lock before you glue it in place.
If it's too deep or too shallow, the key won't turn. And then you drill out the epoxy to get the key out and do it all over again. a PITA
Mr Whiskey
« Reply #9 on: August 12, 2015, 09:07:51 AM »
Gorilla Glue works jus' fine.
Peace, Whiskey.
« Reply #10 on: August 12, 2015, 07:37:27 PM »
I have some Harley end caps off some old grips. That would really throw folks for a loop.  Wink
Hooter
S.W. Michigan
« Reply #11 on: August 13, 2015, 08:15:47 AM »
   Did that years ago on my Road*. Used a chrome semi lug nut cover. At a glance it makes the bike look like there isn't a key in it. Guess that is the  point. 5 minute epoxy works well to but let it set over night.
baird4444
« Reply #12 on: August 13, 2015, 10:46:18 AM »
  I like the way my lugnut turned out....
« Last Edit: August 13, 2015, 10:48:33 AM by baird4444 » Logged
    - ya gotta be SOBER!
     -Cody Baird
WilliamRS
« Reply #13 on: August 13, 2015, 11:01:13 AM »
somebody help me out here....is this just a decorative mod to use while the bike is in use?
 or is this so that the key can be left in the ignition 24/7 even when the bike is unattended?  if so, why?
john
tyler texas
« Reply #14 on: August 13, 2015, 01:55:44 PM »
                               both ....  coolsmiley                                                 because they can ....     Smiley                           $0.02   Wink
« Last Edit: August 13, 2015, 01:57:36 PM by john » Logged
vrcc # 19002
« Reply #15 on: August 13, 2015, 04:25:05 PM »
When reporting a stolen vehicle, one does not want to make a false police report.  If you say you didn't leave a key in it and it is recovered with a key in it (esp. a fancy custom key), it's hard to explain.
On the other hand, reporting that you left the key in the vehicle (assisting them in the theft) can have repercussions in an insurance settlement (as in there might not be one).
If the thief kills or maims himself (or others) in your stolen vehicle you left the key in, a creative plaintiff's shyster might even argue you are partially at fault in the death (maiming ) of his client the thief (or others).  It's happened.
Ergo, I think those hidden keys are cool too, but I would recommend against walking very far away from your bike with any key in it.
Do what you want.
(Yes, very few Valks are stolen... because they are SO damn heavy  2funny)
« Last Edit: August 13, 2015, 04:35:31 PM by Jess from VA » Logged
RDKLL
VRCC #1231 VRCCDS #271
Mesa, AZ
« Reply #16 on: August 13, 2015, 04:33:41 PM »
I did mine with a I/S radio knob
« Reply #17 on: August 13, 2015, 04:36:43 PM »
The IS radio has knobs?
czuch
vail az
« Reply #18 on: August 14, 2015, 07:58:28 AM »
Make it out of an old heater knob, that says heater. That'll throw em.
« Reply #19 on: August 14, 2015, 01:15:11 PM »
Exactly what I was thinking. That little flipper would not look good on a key.  Grin
PharmBoy
Lawton, Ok
« Reply #20 on: August 15, 2015, 12:18:20 PM »
I made one a couple of years ago and soon found that you have to carry an extra key to open the gas cap because if you make the key short enough to look right in the ignition, it is too short to open the gas cap. However, I do like the looks of it enough to carry another key...Jim
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
« Reply #21 on: August 15, 2015, 02:18:39 PM »
Just mark the key in the ignition switch and bury in the fob to the mark... It will work in trunk , saddlebags , gas cap and lock the forks.
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #22 on: August 15, 2015, 03:27:20 PM »
You do need to leave a hair more then the ignition because of the gas cap cover that slides to the side to uncover the key hole can hang you up if too tight.
« Reply #23 on: August 15, 2015, 04:02:51 PM »
I love this idea now, where would one find a chrome heater knob?
I know, if I want one, go find it myself.    Just thought someone might know.  Smiley
« Reply #24 on: August 15, 2015, 04:14:35 PM »
A nice chrome boob/nipple would be nice...... but everyone would be feeling it.
Best to not stand out at all.
« Reply #25 on: August 15, 2015, 04:17:05 PM »
On a Valkyrie?   Very unlikely to happen.  Smiley
