March 23, 2026, 03:33:36 AM *
Author Topic: Parts fro rear wheel service  (Read 1714 times)
BradValk48237
Oak Park, MI
« on: March 03, 2011, 01:58:43 PM »
I have printed out most of the info for rear wheel maintenance...
 Does anyone have a list of the parts and HDL part numbers for all the things I need?
Should I order the thrust washer and seal?
« Reply #1 on: March 03, 2011, 02:31:17 PM »
I think if the thrust washer looks OK, it is probably good. They're cheap, so it wouldn't hurt to
order a new one, then you can form your own opinion about what a good one looks like...
I've never changed my bearing seal, except for the time I changed the bearing (is that the seal you mean?)...
If those rubber bushings that the flange sticks into are all wobbly, it is worth changing them... there's a current
thread about a VRCC member who makes ones that are better than OEM, he is taking orders for a batch he is
about to make...
I just changed my tire, and so far the only other thing I changed out while I was in there is
the brake pads and caliper seals...
Oh yea... if you're changing the tire, put in a new valve stem if you still have the OEM one in there...
Here's one place to get good ones:
http://patchboy.com/mm5/merchant.mvc?Screen=PROD&Store_Code=P&Product_Code=17-562&Category_Code=6-3
« Last Edit: March 03, 2011, 05:19:05 PM by hubcapsc » Logged
