March 23, 2026, 11:18:29 PM *
Author Topic: Turn/brake signal modifications  (Read 2379 times)
« on: June 14, 2011, 02:23:32 PM »
Has anyone done this to there std/tourer?
http://www.electricalconnection.com/other-lighting/tsk-star&sport.htm
Changed their turn signals into running and brake lights.
Any experience with the above company?
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #1 on: June 14, 2011, 02:26:51 PM »
I did it about 5 years ago.  Works great and no issues with the company.
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #2 on: June 14, 2011, 04:43:17 PM »
That is the best single safety upgrade I have made to mine.
I love having additional red running and brake lights, while keeping turn signals yellow.
I have talked friends into the mod on their bikes, and even helped them do it.
Go for it.
Save a horse, ride a Valkyrie
Red Diamond
Beaumont, Texas
« Reply #3 on: June 14, 2011, 04:47:28 PM »
First thing I did when I got my Tourer, not enough light back there for me. Used the Signal Dynamics conversion kit to do mine. Also added the double/high-low LED license plate lights, works fine.
joefromperry
Perry, OH
« Reply #4 on: June 14, 2011, 05:38:07 PM »
I use the Kisan SignalMinder, which not only cancels the turn signals automatically, but turns the turn signals into running lights and gives me four-way flashers for emergencies. Their VectraLights also plug into the SignalMinder to give me turn signals on my mirrors. I've had them on for four years with no complaints.
2000 Honda Valkyrie Interstate Silver/Blue
2002 Honda Shadow ACE Deluxe
1972 Honda CL350K4 Scrambler
2008 Ural Patrol
1987 Honda Rebel 450
X Ring
VRCC #27389, VRCCDS #204
« Reply #5 on: June 14, 2011, 09:24:09 PM »
I did mine with a trailer wiring harness adapter.  Think I found the instructions on Rattlebars website.
Marty
« Reply #6 on: June 14, 2011, 10:35:27 PM »
Firstly, it sound slike there is more than one conversion out there for this kind of thing. I was also thinking of the 4-way flasher mode, put if I recall, I hadn't heard anyone here recommend someone yet.
Thunderbolt
Worthington Springs FL.
« Reply #7 on: June 15, 2011, 02:52:30 AM »
Standard, Tourer and Interstate.  Also Chet's 4 way flashers.  Both work great.  I used the kit from Electrical connection that fit on the bulb itself with a rubber grommet.  Some of their kits are stuck inside the fixture behind the bulb.
vanagon40
Greenwood, IN
« Reply #8 on: June 15, 2011, 08:29:54 AM »
Yes, there are lots of different conversions.  There are kits that add LED for the lamps.  There are modifications involving resistors and diodes.  And one can replace the rear turn signal stalks with front stalks and then use a dual element bulb.
As a general rule, if you convert the turn signals to running lights, they should appear to be red and not amber.  The turn signals may be amber or red.  Brake lights should be red or amber.
hmt81
« Reply #9 on: June 15, 2011, 08:35:32 AM »
I added this LED bar from Electrical Connectiom, mounted above license plate, below taillight. It has running & brake & it is bright.
 Available with clear or red lens
http://wingstuff.com/pgroup_detail/33_lighting_bulbs/31906_red_lens_3rd_brake_light_w_run_option/
« Reply #10 on: June 15, 2011, 08:53:48 AM »
I got one several (two? three?) years ago. I never got around to installing it, though there's good instructions that come with it,
and there's more good instructions over at bigbf:   http://bigbf.com/bigbf_shop/rear_turn_signal_kit/
The way that LEDs keep getting better every year, I'm afraid that the two-or-three year old one I have won't be as good
as a new one.
Always install your stuff right after you get it  cooldude
Paxton
So Cal
« Reply #11 on: June 15, 2011, 04:32:08 PM »
I am in the process of stripping all OEM rear lights. I removed the entire lic plate OEM assembly and the main light fixture at the top.
The custom license plate bracket is now bolted into the depressed area where the OEM rear-main light fixture resides.  Undecided
The wiring behind the OEM light fixture still provides the wiring for running and stop lights.
It tucks in nicely behind the license plate.
The remaining holes are taped over with "Trim Tape." When done with the mods, I'll have the fender tail smooth out and repainted to match...
The small rectangular running lights above the OEM license plate are now mounted above the new license plate location.  coolsmiley
The signals are now coming from the saddlebag lights.
For brake lights I purchased two 9" led strips which can be placed virtually anywhere on the bike...
no screws, just 3M tape. I placed mine vertically,along the rear fender starting down from the bottom of the license plate.
https://picasaweb.google.com/103917731019176896112/4TruckStackPipesBeforeAfterPhotos?authkey=Gv1sRgCLPpuLLMxrjV2QE#5617986329609140210
They come in 15" and 9" long stripes. Either pair is $15.99. I purchased mine with Red bulbs, but they come in different colors...
(White, Blue, Amber, etc...).
I purchased them at one of the popular chain auto parts... not Pep Boys, not Kragen... err... Senior Moment in progress!  Embarrassed
My $0.02.
J. Paxton Gomez
1978 Honda 750F / Cafe Racer
So Cal... 91205
« Reply #12 on: June 15, 2011, 06:17:47 PM »
Yes.  Excellent product and I highly recommend the service at Electrical Connection.
« Reply #13 on: June 15, 2011, 06:22:44 PM »
Yep......
Honda Valkyrie - LED turn and tag light modificationspowered by Aeva
bigguy
VRCC# 30728
Texarkana, TX
« Reply #14 on: June 16, 2011, 08:48:52 AM »
I was about to make some smart aleck remark about Cylons until you showed how it works with signals and brakes. That is COOL!  cooldude
It sure ought to get the attention of the driver behind you.
Here there be Dragons.
