March 24, 2026, 01:30:43 PM *
Author Topic: IS Trunk hinge rattle  (Read 2031 times)
cef2lion
Central PA
« on: July 14, 2011, 11:18:40 AM »
I have a annoying rattle that I think is the result of the trunk hinge pins. I wonder if I replace the hinges with new if the new hinges will have the same issue? I did try and put some felt that is sticky on one side to help support the hinge when it is closed. No luck so far unless I didn't build it up enough or the noise is coming from somewhere else.
Craig
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #1 on: July 14, 2011, 11:55:17 AM »
I used the thick felt sticky pads (about the size of a 1/2 dollar), and it worked...  Maybe go thicker?
Black Dog
Don't you know...
designer
Columbus, Ohio
« Reply #2 on: July 14, 2011, 01:57:12 PM »
I replaced and it didn't help.  going the felt route next.
2002 Valkyrie Std
K&N Filter, Audiovox Cruise, I/S bags and trunk, Cee Bailey shield +2, ECT mod, radiator pods, driving lights, rattlebars kick shifter ,I/S ICM
Michvalk
Remus, Mi
« Reply #3 on: July 14, 2011, 02:45:57 PM »
Almost bet money the rattle is coming from a loose speaker/speaker box in the armrest. Mine loosens up regular cooldude
Steve K (IA)
Cedar Rapids, Iowa
« Reply #4 on: July 14, 2011, 08:46:43 PM »
It is the pins in the hinges.  I noticed it shortly after buying mine new in 2000.  Had the dealer give me new hinges, pins were as loose as the ones on the bike.  I used some 1/8" thick rubber with double sided tape to hold in place between the hinges.  One piece on top and one on the bottom so that when the trunk closes, it adds some pressure between the hinges and the pins stop rattling.  After 11 years, mine are starting to make noise, will have to redo them.  This time I will have to use some felt dots as I don't have anymore of the rubber.
States I Have Ridden In
RudyF6
Chelsea, Michigan
« Reply #5 on: July 15, 2011, 06:34:55 AM »
I used some stick-on rubber "feet" from the cabinetry section at the hardware store, about 3/4" square and 3/8" tall.  Stuck one on each hinge next to the pin. Just a couple bucks for a card with 8 on it. Been there for 5-6 years now and works fine.
You can never be lost if you don't care where you're going!
98 "Tourerstate" (Std. with I/S bags/trunk)
98 Tourer solo ride
81 CBX
Steve K (IA)
Cedar Rapids, Iowa
« Reply #6 on: July 15, 2011, 03:39:57 PM »
Thanks for that heads up.  cooldude
Kingbee
VRCC# 576
Northern Illinois
« Reply #7 on: July 15, 2011, 05:35:45 PM »
Here's the stick-on rubber bumpers I've used opposite the screws above.  No more rattles
1999 Interstate
2000 Interstate
2004 Rune
Michvalk
Remus, Mi
« Reply #8 on: July 15, 2011, 06:25:37 PM »
Today, after posting about the speaker boxes loosining up, I looked at my trunk. Mine has a square piece of rubber/foam between the hinge pieces. It lays behind the screws and supports the upper hinge area. But, I have no idea if they came stock or not. I still have a problem with the screws coming loose in the speaker box, but the hinge don't rattle. Grin cooldude
