March 24, 2026, 01:30:38 PM *
Author Topic: plastic bracket thingy on the valve stem....  (Read 2528 times)
YoungPUP
Valparaiso, In
« on: July 16, 2011, 06:09:00 PM »
The Valk had an argument with a rabbit on the way to work the other morning. No real damage, front tire grabbed it. Drug it for a trip through the feender, and then spit it out. went to check the air pressure this morning before leaving to do errands and noticed the plastic thing for the valve stem is gone.  ( Guess the rabbit got a souvenir). Anyone know if there is a metal version available, or at least a shiny version?   And where to get it?TIA
99 STD (Under construction)
Grumpy
Tampa, Fl
« Reply #1 on: July 16, 2011, 06:13:07 PM »
Valkyrie bling has chrome ones. Here is the address,
http://www.valkyrieblingandmore.com/chvastho.html
« Reply #2 on: July 16, 2011, 06:25:07 PM »
Remember, that 'elbow' is there to keep the POS OE rubber valve stem from flexing to the point of cracking with traumatic deflation due to age, deterioration, and centrifugal force.  Replace the elbow soonest, and replace the whole 2-piece OE stem with metal 90* stems at the next tire change.
Mr. Nuts
Bitterroot Valley Montana
« Reply #3 on: July 16, 2011, 06:49:13 PM »
I think OEM valve stems are dangerous even with the bracket. They crack at the worst possible place and time. Let all your air out at speed. Not good. Best to replace them with something solid all the way through. 90 degree bend makes it easy to air up. Here's what I use:
http://patchboy.com/mm5/merchant.mvc?Screen=PROD&Store_Code=P&Product_Code=17-562&Category_Code=6-3
“Speed has never killed anyone.... Suddenly becoming stationary, thats what gets you.” - Jeremy Clarkson
Thunderbolt
Worthington Springs FL.
« Reply #4 on: July 17, 2011, 05:39:13 AM »
+1 on the metal stem.  Until then, replace the plastic one.  If you will send me your address I have an OEM in the plastic bag from Honda that I got before I changed to metal stems.  No charge, I don't need it.
It keeps the OEM stem from flexing especially at higher speeds and allowing air to escape.
FryeVRCCDS0067
Brazil, IN
« Reply #5 on: July 17, 2011, 05:59:03 AM »
Do you still use the plastic support with this type?
« Reply #6 on: July 17, 2011, 07:01:01 AM »
Don't need to use the support, but you could if you wanted it there "for looks" or if you
didn't want to loose it or whatever...
The patchboy-style stem is the way to go  cooldude
vic
East TN
« Reply #7 on: July 17, 2011, 08:37:18 AM »
I just put those patchboy stems on a new set of tires for my Goldwing and plan to do the same with my Tourer when it gets new tires this Fall.  Are those metal stems reusable or do you change them out with each tire change?
« Reply #8 on: July 17, 2011, 08:52:29 AM »
The metals are lifetime (unless you damage one, unlikely).
X Ring
VRCC #27389, VRCCDS #204
« Reply #9 on: July 17, 2011, 11:28:02 AM »
Patchboy sells on ebay with $5 shipping unlike that outrageous shipping charge they have on their own site.
Marty
hmt81
« Reply #10 on: July 17, 2011, 12:40:01 PM »
Just installed new Avon's 2 months ago from Jake Wilson and picked up these stems. They look & work great and the OE plastic support still fits on it eventhough it is not needed.
http://www.jakewilson.com/productDetail.do?navType=type&webTypeId=321&navTitle=Motorcycle+Tire+Accessories&webCatId=38&keyword=valve+stems&prodFamilyId=19082
