March 24, 2026, 10:07:03 AM *
Author Topic: Petcock rebuild....any tips  (Read 2320 times)
Davemn
Minnetrista, Minnesota
« on: July 30, 2011, 05:36:24 AM »
My parts are coming Tuesday for a complete rebuild. Looking for any advice.
Also, I see references to the vauum line to #6 cylinder. The line from the petcock appears to run to the rear cylinder on the left (clutch) side of the bike. Maybe I didnt see it right.
« Reply #1 on: July 30, 2011, 05:43:39 AM »
That is #6 cylinder. The line is the source of vacumn for the petcock. Fuel will not flow without it.  Hoser
« Reply #2 on: July 30, 2011, 07:42:24 AM »
Tip: Pingel  Wink
NITRO
Eau Claire, WI
« Reply #3 on: July 30, 2011, 07:47:42 AM »
I've had to rebuild mine twice in the last year, it's a 30 minute job once you have it down. Just keep everything in order and note which side faces in as you go so that you know how to put the new pieces in. The worst part of the whole job is getting the tank bank on.
When in doubt, ride.
Bone
« Reply #4 on: July 30, 2011, 08:14:37 AM »
While waiting for the kit I converted mine to manual. Kit has been here a year or two I'm happy with on/off manual.
Brian
Monroe, NC
« Reply #5 on: July 31, 2011, 06:02:06 PM »
dido on the manual. cooldude No more issues.
« Reply #6 on: August 01, 2011, 08:53:57 AM »
You're probably not looking for this, but, I think the best tip is : install a Pingle.. I know, I'm goin' to #$%@ for saying that !  Roll Eyes
valkyriemc
NE Florida
« Reply #7 on: August 01, 2011, 05:37:27 PM »
It it what it is. You said it, I thought it too & I'm glad I'm done with them.
Veteran USN '70-'76
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #8 on: August 01, 2011, 06:22:14 PM »
Are there instruction on converting it to manual?  Thanks
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
Bone
« Reply #9 on: August 02, 2011, 03:47:56 PM »
Zeus661 someone posted some instructions that is when I did mine. I thought I saved the info and must have hid it well I haven't found it yet. I will keep looking.
You do understand the petcock has to be turned off when not in use. I rode most of my life with manual fuel valves they are not for everyone.
Bone
« Reply #10 on: August 02, 2011, 04:16:51 PM »
Well I found the link that shows the conversion on a similar petcock.
This is the one I used. Looking through my files I ordered the cover set
in March 2010.
http://www.daughertymotorsports.com/howto/Tankvalve/tankvalve.html
Mr.BubblesVRCCDS0008
« Reply #11 on: August 02, 2011, 04:42:31 PM »
Did mine about 4 years ago. I just removed all rubber parts and placed a thick piece of gasket material between the two parts where the diaphram was. It seals off the vent and vac. port from the wet side and makes the valve totally manual. cooldude
NITRO
Eau Claire, WI
« Reply #12 on: August 02, 2011, 06:13:04 PM »
As added insurance, you might consider adding an electric fuel valve if changing to a manual petcock. Since mine has failed twice in a year, I'll be doing it at some point.
