March 24, 2026, 10:05:22 AM *
Author Topic: Brief run-in with Murphy today  (Read 2087 times)
Fudd
MSF RiderCoach
Denham Springs, La.
« on: August 01, 2011, 07:00:18 PM »
I went to leave a Patriot Guard mission this evening in pouring rain and I didn't have ANY electrical power.  I wiggled the wires on the starter relay and the power came back.  It started, and I left for home.  Two miles from home, still in the rain, but now dark, I lose all electrical power and the bike dies.  I brake hard, turn in a driveway and "poof," the power is back, it starts and I'm home.
Before anybody suggests for me to check the starter switch, it's not that.  TOTAL electrical failure, not just headlight and starter function.
I'm about to go see about a loose connection now.  I'm also going to look at the wiring diagram to see where or what around the starter relay can be giving me an open connection.
Ideas appreciated.
Save a horse, ride a Valkyrie
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #1 on: August 01, 2011, 07:24:50 PM »
Well, that was easy enough to find.  The red plug on top of the starter relay had melted.   There was a poor connection at a loose blade connector.  The insulation was burnt off the wire as well.  Hopefully the relay can hold up till I get another one.  But for tonite, I'll replace a few inches of wire and replace the blade connector.
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #2 on: August 01, 2011, 09:42:21 PM »
Here's what the top of the relay looked like.
Looked like it got kinda warm, huh.
RonW
Newport Beach
« Reply #3 on: August 02, 2011, 05:02:46 AM »
That red wire is a main artery OUT, and the defect will stop you smack dab in the middle of a highway if vibration disconnects it. Fortunately, Valk engines run smooth. The red wire came off at the crimp on my other bike's relay and ruined a battery before I stumbled upon it. Do you think that on a Valk, it's caused by the rubber boot not being large enough to fully cover up the starter-relay unit? Water eventually seeps in?
2000 Valkyrie Tourer
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #4 on: August 02, 2011, 06:36:49 AM »
Well, if the rubber boot wasn't big enough before, it sure ain't now- with a big hole burned in it.
I'm going to check with the junk yard to see if they'll sell me a plug with 3 or 4 inches of wire that I can splice in.  I'll get another relay, too.  This one has been "thermally compromised."
« Reply #5 on: August 02, 2011, 05:20:05 PM »
After reading a few of these posts n the past, I cleaned all the contacts on the relay and coated them with a dielectric grease. 121K miles and no problems (YET).
« Reply #6 on: August 02, 2011, 05:34:37 PM »
At this link you will find a replacement connector that will work on the Valk.   I have one on mine.    Change the red wire to the empty plug, put on the new extra large rubber boot and good to go.
http://www.jkozloski.com/generic_parts.htm
Find 'Starter Relay Repair' down towards the bottom on the right.
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #7 on: August 02, 2011, 08:27:32 PM »
Thanks R J for the link, "you da man"
I'd seen this before but forgot about it.
