March 24, 2026, 10:05:32 AM *
Author Topic: Leak in final drive  (Read 1656 times)
VALKBERRY
« on: August 01, 2011, 08:23:37 PM »
Guys,
Got a leak on the inside of the final drive, next to the rear wheel. This leak reared it's ugly head after repairing the rear flat I accumulated in the middle of nowhere. I'm sure I bruised the seal trying to seperate the hub from the drive as it was difficult to remove. Will this require a total break down of the unit? or can I replace the seal with a pick? Help would be greatly appreciated.
« Reply #1 on: August 02, 2011, 04:26:55 AM »
the latter....just make sure you clean the area well so no funky stuff gets inside
hmt81
« Reply #2 on: August 02, 2011, 04:42:14 AM »
Had the same issue a few months back, got too excited trying to pry the drive plate with a screwdriver when removing the back wheel for the first time. I nicked the seal and she was leaking fairly bad. I did as the guys here directed and used a small nail and put a hole in the seal, threaded in a small screw and then pulled the seal out by the screw. Lube up the new seal with gear oil and pressed in place by hand. All is well. I think the manual leads you down a different & more difficult route. It was really quite simple.  cooldude
VALKBERRY
« Reply #3 on: August 02, 2011, 07:31:21 PM »
Thanks guys. Feel much better now. I'll know better next time I use the screwdriver.
