March 24, 2026, 06:38:55 PM *
Author Topic: ECT mod advice.  (Read 4029 times)
jarid
sacramento CA
« on: October 16, 2011, 07:28:08 PM »
I would like to hear from those that have done this mod.
what do you think of it?
would you do it again?
what about MPG?
what about performance?
Thanks in advance.
Thinking men cannot be ruled!
Momz
ABATE, AMA, & MRF rep.
« Reply #1 on: October 16, 2011, 07:46:28 PM »
I did the "simple ECT Mod"on my 98.
The torque curve is a bit better, thus better acceleration below 3.2K in any gear..
I do get great mileage but I can't say it is due to the ECT Mod.
I also have an 2K I/S with a 4 degree TW; wished I knew about the ECT Mod before I put in the TW.
My next Valk (A 97) project bike will also get this modification ASAP.
ALWAYS QUESTION AUTHORITY!
jarid
sacramento CA
« Reply #2 on: October 16, 2011, 07:59:47 PM »
« Reply #3 on: October 17, 2011, 05:24:20 AM »
Seems to have more power. Hardley ever have to use my choke. No change in my mpg.
Rick Groseclose
(VRCC #5362)
Lexington, SC
« Reply #4 on: October 17, 2011, 11:18:50 AM »
Sorry, what is the ECT mod?????  I have a '99 I/S with the advanced TW.  Would this be a good move for me?  Thanks, Rick
Rick, Lexington, SC
tank_post142
south florida
« Reply #5 on: October 17, 2011, 12:03:50 PM »
http://www.valkyrieriders.com/shoptalk/ect-mod.htm
check out shoptalk, lots of info!
I got a rock Sad
VRCCDS0246
John U.
Southern Delaware
« Reply #6 on: October 17, 2011, 02:24:31 PM »
I did the ECT mod on two Valks, one Tourer and an I.S.. I installed a potentiometer so I can dial in just part of the 10 degree difference in advance. I use midgrade gas to avoid pre-ignition.
Since I can turn the advance off, it's easy to see what difference it makes. I get a couple of mpg more with the ETC mod working. Unless I have too much fun with the throttle.
I like it and would do it again.
designer
Columbus, Ohio
« Reply #7 on: October 17, 2011, 02:35:27 PM »
Did the ECT mod and lost 2mpg.  Except for increased RPM it was hard to start and really didn't help my bike at any setting.  I haven't used it since.
2002 Valkyrie Std
K&N Filter, Audiovox Cruise, I/S bags and trunk, Cee Bailey shield +2, ECT mod, radiator pods, driving lights, rattlebars kick shifter ,I/S ICM
John U.
Southern Delaware
« Reply #8 on: October 17, 2011, 02:52:18 PM »
It's just my guess and may be wrong but I wonder if the reaseon that some get no improvement in mileage or worse is that 10 degrees advance is just too much advance. Try installing a potentiometer from Radio Shack and set it to 1/2 of the rpm increase.
I bet your mileage will show an improvement. Though as always, YMMV
jarid
sacramento CA
« Reply #9 on: October 17, 2011, 09:03:22 PM »
May not be right for the interstate as it allready has extra advance
« Reply #10 on: October 18, 2011, 07:32:03 AM »
Not really.
Either modification are duplicative and employing both could possibly lead to motor damage through misapplication.
tank_post142
south florida
« Reply #11 on: October 18, 2011, 08:22:51 AM »
i've got to agree with Rick on this one. if you have 4-6 degrees of advance with the trigger wheel, then add 10 degrees of virtual advance, you might be in trouble.  Shocked
I got a rock Sad
VRCCDS0246
designer
Columbus, Ohio
« Reply #12 on: October 18, 2011, 09:40:45 AM »
I tried everything to get that to work.  Mine has the pot attached and I did 3 tanks at 50% and 3 tanks at 100% and both were lousy.  Mine just didn't like the advance with the current stock (?) carb setup.  I will be doing some tuning this winter and try again in the spring.  maybe with a well tuned bike its better.
2002 Valkyrie Std
wild6
(Old enough to know better)
Vernon, NJ
« Reply #13 on: October 18, 2011, 10:47:42 AM »
I did the ECT mod.  Gave me about 4mpg more.
I think it's better than the trigger wheel because:
1. It is (optionally) adjustable up to 10°.
2. It makes the bike easier to start when cold because it doesn't add to the ICM's advance.
3. It's disabled when the transmission is in neutral preventing high idle rpm.
4. It fades out above 3k rpm letting the ICM do the job.
If not using the pot, I'd suggest you use a 1k resistor instead. (close to the center of the pot's adjustment)
It's important to use an audio taper pot (not linear).
Adding the pot gives you a resultant resistance range of 0-2800 ohms with 800 ohms being at the center.
I had the usual problems with the 6° trigger wheel before removing it and going with the ect mod.
Never looked back.
« Last Edit: October 18, 2011, 11:08:45 AM by wild6 » Logged
sugerbear
wentzville mo
« Reply #14 on: October 18, 2011, 11:10:46 AM »
if you didn't buy it new, are you sure it doesn't have and aftermarket trigger wheel?
jarid
sacramento CA
« Reply #15 on: October 18, 2011, 04:55:59 PM »
Great responses guys I really appreciate it.What about exhaust mods I am thinking of 18 in glasspacks.I dont want annoying at steady RPM but throaty/deep.what doe you reccomend?
Thank in advance.
John U.
Southern Delaware
« Reply #16 on: October 18, 2011, 05:01:51 PM »
You should start a new thread on the glasspack question. You will get more helpful responses. Besides, it's bad form to hijack your own thread.  Grin
tank_post142
south florida
« Reply #17 on: October 18, 2011, 06:00:43 PM »
 2funny 2funny 2funny
I got a rock Sad
VRCCDS0246
jarid
sacramento CA
« Reply #18 on: October 18, 2011, 06:59:52 PM »
Sorry for the rookie move.
John U.
Southern Delaware
« Reply #19 on: October 18, 2011, 08:05:13 PM »
No need to apologize. Around here on a scale of 1 to 10 that infraction doesn't even rate a .5  cooldude
