March 24, 2026, 06:39:09 PM
Are front turn signal end pods interchangable?
Topic: Are front turn signal end pods interchangable? (Read 1669 times)
Valk-N-Indy
October 17, 2011, 12:04:49 PM »
I have a smashed left turn signal "end pod", the mounting part is still intact. I was wondering if anyone knows it the right and left are interchagable. I have not looks closely enough yet and can probably figure it out when and if I take the time, but I figured it does not hurt to ask the experts.
YoungPUP
Valparaiso, In
Re: Are front turn signal end pods interchangable?
October 17, 2011, 12:10:09 PM »
If you've got the old style 2 screw lenses they appear to be interchangable, but if you've mashed one of the newer single screw, the they are side specific. Check with the local stealer for take-offs, they are a lot cheaper. If they don;t have any, check pinwall, dennis kirk has them as well.
99 STD (Under construction)
Sambeaux
'99 Std
Daphne, Alabama
October 17, 2011, 01:03:09 PM »
I belive the single screw light assembly off the VTX is interchangable as well. These are side specfic - at least the once I used to modifiy my rear turn signals were.
Sambeaux
'99 Std
Daphne, Alabama
October 17, 2011, 05:09:44 PM »
Just stumbled on this ebay store (no association).
http://stores.ebay.com/HIT-THE-GAS/_i.html?_nkw=valkyrie&submit=Search&_ipg=30&_sasi=1&_sop=1&_vc=1&_sid=120606839
If the link doesn't work do a search with ebay on HIT-THE-GAS then do a site search on Valkyrie.
I purchased a set of VTX Frt turn signal at a salvage yard for the same price - better deals are out there if you have time to look.
Valk-N-Indy
October 18, 2011, 06:04:38 PM »
I do have the old 2 screw lenses YoungPUP discribed. Thanks to everyone for your input. I have a better Idea of what to look for now.
tank_post142
south florida
October 18, 2011, 06:17:14 PM »
they are cheaper from Honda!
http://www.dealercostparts.com/pages/OemParts?aribrand=HOM#/Honda/GL1500C_A_%2898%29_MOTORCYCLE%2c_USA%2c_VIN%23_1HFSC340-WA100001/TURN_SIGNAL_%281%29/GL1500C-98-A/2Y14MZ0VMZ04F2700BA
I got a rock
VRCCDS0246
