March 25, 2026, 09:46:57 AM *
Author Topic: Wiring to a ground/negative question.....  (Read 1521 times)
« on: February 23, 2012, 02:30:39 PM »
Another stupid question (indulge me please  Wink)......Wiring up my stereo in my Woodys fairing.  The stereo's (Sony DSX-S100) installation manual (which isn't all that clear) calls for installing the black negative/ground wire to a chassis/frame ground.
Thought about runing it to the triple tree, but Ricky-D changed my mind for me.   Wink  Is there any reason why I can't wire it to a negative terminal on my fuse block, or should I stick to the instructions and wire it to a frame ground.
The last time I hooked up a stereo was back in the early 70's when I hooked up my Craig 8 track.   Shocked
« Reply #1 on: February 23, 2012, 02:38:51 PM »
The negative terminal on your fuse block should be OK, assuming you sized it big enough that you don't have to worry about load & capacity.  However, move the other end of that ground to the steel frame, if it's still on the engine block.  Then add a grounding strap between the engine block and the frame.  Pay particular attention to the connection on the block - I use electrically conductive compound.  One is made by Ideal - P/N 30-026, called NOALOX Anti-Oxidant Joint Compound.  It is specifically for making electrical connections to aluminum.  Another product is Quick Start Copper Formula Electrical Connection Compound.  I also had a similar compound provided by Lincoln Electric, when I had to replace the big capacitors on a MIG welder, it was for improving conductivity of aluminum connections.  I'm sure you can find at least the first one above, online.  Or something that does the same thing at a welding supply or other electrical supply store.
« Last Edit: February 23, 2012, 02:49:32 PM by MarkT » Logged
« Reply #2 on: February 23, 2012, 02:51:14 PM »
Alrighty.......I've extented the wire with enough to get back to the battery area on the bike.  I can either wire it direct to the PC-8 negative.....opposite where I'm putting the yellow power wire (fused 15 amps as recommended)......or run it to a frame ground.
Which way should I go here?
« Reply #3 on: February 24, 2012, 09:15:59 AM »
frame  cooldude In fact one coil is closer to the front of the bike and under the tank and it held on by 2 easily accessible bolts you could use this too.
« Last Edit: February 24, 2012, 09:17:33 AM by Robert » Logged
