March 25, 2026, 09:46:55 AM
Speedo Cable Lube
Topic: Speedo Cable Lube (Read 1518 times)
Biker Bill
Speedo Cable Lube
February 23, 2012, 04:29:12 PM »
I owned a 99 GL 1500 and had a problem with the speedometer cable breaking due to inadequate lubrication.
Any tips on how to remove and lube the speedo cable on my 2000 Valk standard? Want to do this before problems occur.
F6BANGER
Albuquerque NM
Re: Speedo Cable Lube
February 23, 2012, 04:32:36 PM »
Unscrew it from the speedo and lube it and screw it back in.
GOOSE
D.S. #: 1643
Southwest Virginia
February 23, 2012, 05:06:38 PM »
You take it apart at the wheel....Unscrew the phillips screw and pull the housing loose from the wheel....As you pull the cable from the sheath pull the cable through a clean rag...Then put a glob of lubriplate in your hand, and coat the cable with the lubriplate as you slide it in.
February 23, 2012, 05:54:34 PM »
Yep, just remove and clean the cable, reinstall with Lubriplate or White Lithium grease..
Biker Bill
February 24, 2012, 03:31:23 PM »
Thanks guys for the info. Sounds like something I can do to avoid the $75.00/hr shop fee!
Big IV
Iron Station, NC 28080
lube goes down hill
February 24, 2012, 03:36:05 PM »
It seems like removing the top should be the lube point. Maybe that is harder on an interstate. I've broke my second so I probably need to lube mine more often.
"Ride Free Citizen!"
VRCCDS0176
Joe Hummer
Arnold, MO
Re: lube goes down hill
Reply #6 on:
February 24, 2012, 04:27:02 PM »
Quote from: Big IV on February 24, 2012, 03:36:05 PM
Hey Big...The IS has an electronic pick-up for the speedo.
1999 Valkyrie Interstate
