March 25, 2026, 09:47:00 AM *
Author Topic: Carb Work - Update  (Read 1816 times)
Bigwolf
Cookeville, TN
« on: February 23, 2012, 08:52:10 PM »
I finished the work on the carbs today.  Wow!  Much stronger and smoother running.
My Manometer:
I built this manometer with long tubing connectors but I also put a resonator/absorption chamber (piece of pipe) in each line that serves 2 purposes. 1) The added volume of air in it absorbs most of the pulse fluctuations making the meter easy to read.  And 2) these pipe chambers are large enough that any one of them will hold all of the fluid in the entire manometer system thereby eliminating the worry of sucking anything into the engine if a leak developes somewhere.
My Valk hooked to the manometer:
I use short pieces of copper tubing connected to intakes with short pieces of viton to keep my plastic manometer tubing away from hot parts while syncing the carbs.
This is what I found when I got the carbs off and began to go through them: 5 bad air cut valves, a bad PAIR control valve, and cracked hoses on the air cut valves.  I had to laugh at myself because I had read on the board that replacing vacuum hoses was a good place to start when trying to chase down leaks and I had replaced all the hoses on the manifolds but never noticed the hoses to the air cut valves.   uglystupid2
Since 5 out of 6 air cut valves were leaking and I did not have the budget to buy them this month, I plugged each of the bad ones off.  I figgured I would start with the pilot screws a bit farther out than for normal just to keep decel popping down.  Well I did not notice any decel popping so I will adjust these a little bit sometime soon.
Anyway, the front wheel is leaving the ground when going into 2nd so I think all is doing pretty well now.  It is still not as fast as it was when I bought it, but that is another story.
Wolf
RonW
Newport Beach
« Reply #1 on: February 23, 2012, 09:36:57 PM »
fantastic!
2000 Valkyrie Tourer
Mr Steve
Feeding Hills, MA
« Reply #2 on: February 23, 2012, 10:43:30 PM »
I like it.  Do you have more details on that manometer design?  Maybe a few more pics of both sides and some parts specs?  I'm looking to build one myself and this looks like it may be a better design than the others I have seen here.
olddog1946
Moses Lake, Wa
« Reply #3 on: February 23, 2012, 10:54:36 PM »
It does indeed look like a well thought out set up, I'd bet there are many of use would like to know more about it. cooldude cooldude
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
« Reply #4 on: February 24, 2012, 09:26:27 AM »
UH OH!!!!!! the old Im used to it now wasnt as fast as it was,, I need a supercharger syndrome. Be careful this leads to excessive contemplation on bike performance with a decline in check book reserves  2funny 2funny
capehoorn
Grand Rapids, Michigan
« Reply #5 on: February 24, 2012, 04:15:30 PM »
Nice work!!!!! I need to make a set up just like that this week. Could you post detailed plans and specs?
2000 Interstate
Bigwolf
Cookeville, TN
« Reply #6 on: February 24, 2012, 05:03:09 PM »
So my version of a home built manometer has garnered some interest.  Well I will certainly share my thinking on it.  I made it a few months ago mostly out of leftovers from other projects so I will have to take some more pics, check and write down the measurements.
I will try to get it written up and posted within the next couple of days.  I will do that in a new thread.
Wolf
Bone
« Reply #7 on: February 24, 2012, 05:18:41 PM »
The manometer got my attention and the wooden boxes under the wheels. I always put something under mine more to stabilize than for support. If the bike doesn't start moving it stays very secure.
