March 25, 2026, 09:47:02 AM *
Author Topic: wiggling the piggies  (Read 1497 times)
YoungPUP
Valparaiso, In
« on: February 24, 2012, 05:31:55 PM »
Am working on a few ideas, Have been checking the temps on/in the tips, and am thinking that I should be able to pet leds into the tips, bot to give me some more space for heat protection, Id like to get the ends of the piggies together in the middle of the cobra tips that I installed on to my interstate pipes.  The i/s piggies were trimmed to just short enough to hide inside the tips.  I'm wanting to try getting them into a teepee type arrangment at their ends,  how hard are they to bend/adjust?  Maybe some heat?
99 STD (Under construction)
« Reply #1 on: February 24, 2012, 05:45:05 PM »
A hand-held tuging bender may work, but then again, might be too combersome and too expensive for the home hobbiest.
You might could try a set of spring tubing benders......
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?productId=100647941&storeId=10051&langId=-1&catalogId=10053&ci_src=14110944&ci_sku=100647941&cm_mmc=shopping%2d%5f%2dgooglebase%2d%5f%2dD27X%2d%5f%2d100647941
sugerbear
wentzville mo
« Reply #2 on: February 24, 2012, 07:06:05 PM »
or, if the piggies can't be seen anyway, build the shape you want, wire it up and mount it in there.....just thinkin Undecided
