March 25, 2026, 05:50:47 PM *
Author Topic: Spark plug wires  (Read 1413 times)
mario
NW Houston, TX
« on: March 16, 2012, 12:00:45 PM »
Hey y'all,
I'm probably needing some spark plug wires. Do you use Honda or after
Market? If so, from where?  OR does anyone have newish ones they don't need?
I'm on the road, will check back.
Mario
01 Valkyrie Standard (sold)
12 Suzuki V-Strom 1000
BonS
Blue Springs, MO
« Reply #1 on: March 16, 2012, 12:46:22 PM »
You can buy 7mm wires and reuse the original plug boots. John Schmidt did a good write up on that. www.valkrieriders/Shop Talk/plugwires.pdf
OEM wires are still available as well. You can also just do away with the OEM boots and use conventional ones as long as you keep the drain holes clear. I'd just be sure to use copper wires and a 5K ohm resistor plug cap (boot).
